C5 Corvette Odometer Side Buttons
Old Mar 28, 2024 | 11:47 PM
Ikarah's Avatar
Ikarah
Default C5 Corvette Odometer Side Buttons
Hey all,
I am not sure why these buttons do nothing on the C5 I purchased is it because i have active codes on the display?
Old Mar 29, 2024 | 01:51 AM
Moved to C5 Tech.
Old Mar 29, 2024 | 09:40 AM
Markolc1981's Avatar
Markolc1981
Yes. Use reset to clear all the immediate warnings and then you can cycle through the display options.
Old Mar 29, 2024 | 10:32 AM
Ikarah's Avatar
Ikarah
Moved to C5 Tech.
Apologies for not putting those in the right area will post in tech next time.
Old Mar 29, 2024 | 10:33 AM
Ikarah's Avatar
Ikarah
Awesome, ty!
Old Mar 29, 2024 | 11:58 AM
feeder82's Avatar
feeder82
Here's another link that may help with the DIC button issues
https://www.corvetteforum.com/forums...t-working.html
Old Mar 29, 2024 | 01:10 PM
Ikarah's Avatar
Ikarah
I tried to access the codes menu and couldn't, I messaged the PO and he told me the DIC didn't work. Is it hard to replace just that or does the whole instrument cluster have to come out? I am looking at the thread you shared in the meantime.
Edit: found my answer around replacement in that thread.
Old Mar 29, 2024 | 01:49 PM
Ikarah's Avatar
Ikarah
So this is interesting, I tried the simplest suggestion first which is checking if the DIC lights up and if the buttons are stuck. I pried the buttons out and the DIC is lit but, when I push the buttons that I can see with a flat head that part of the cluster dims, when I install the buttons and push them in that doesn't dim? I am not sure if these are the same buttons that should get pushed when I push the physical ones in? I noticed there are only 3 of those vertically.
Here is a video to clarify this more:
Old Mar 30, 2024 | 11:46 AM
Ikarah's Avatar
Ikarah
I scanned the car and did some digging, I am getting these errors from the DIC
where do i go from here?
Old Mar 14, 2026 | 12:37 PM
Nowanker's Avatar
Nowanker
Pro Mechanic
Delete
Last edited by Nowanker; Mar 14, 2026 at 12:40 PM. Reason: Stupid scroll down to 'related' thread...
Old Mar 16, 2026 | 10:18 AM
grinder11's Avatar
grinder11
Turn key on, clear any messages in the DIC by using reset button until it is blank. Push and hold options button down. While holding options button down, press and release fuel button 4 times within 10 seconds. Codes, if any, will come up in DIC. Do a search on clearing C5 codes for more info. GM will NEVER build another car with onboard diagnostics. Oh BTW, you'll become very adept at using this function as time goes by, trust me!!!
To C5 Corvette Odometer Side Buttons
