PCV Issues
Old Apr 2, 2024 | 01:14 PM
Jakeonio's Avatar
Jakeonio
Default PCV Issues
To those of y’all with catch cans can you confirm routing? I have an 02Z and following elite Engineerings chart, I have gone from valley pan to top of the catch can, and catch can to intake manifold. The PCV valve is supposed to flow into intake manifold, correct? I swear I installed correctly but a week later I noticed a large oil leak and it looks like pressure built up and blew out my valve cover gaskets, and I fear a leak at the oil pan as well.
Popular Reply
Apr 2, 2024, 10:45 PM
aaronc7's Avatar
aaronc7
He is definitely wrong and confused...and strangely over confident about it. Only the 04s had the fixed orifice valley cover / pcv system. 30 seconds on google will confirm.
I have a 2003 C5 Z06... behold:
Old Apr 2, 2024 | 01:36 PM
lucky131969's Avatar
lucky131969
Post pics of your install.
Old Apr 2, 2024 | 04:49 PM
Lawandorder's Avatar
Lawandorder
Banned Scam/Spammer
Here is a video for install on your car
https://youtu.be/231OyFOVvF0?si=NBR-CEVEdXhhRQRq
Old Apr 2, 2024 | 05:33 PM
captain vette's Avatar
captain vette
Sounds like it’s routed correctly, it’s how mine is install without any issue
Old Apr 2, 2024 | 05:37 PM
Lawandorder
Banned Scam/Spammer
what m in the world is going on there????? That external valve is NOT oem and shouldn’t be there
Old Apr 2, 2024 | 06:01 PM
Smoken1's Avatar
Smoken1
Looks to me like an aftermarket PCV valve and for 01-03 should definitely be there. Not everyone buys thier parts from the Dealer
Old Apr 2, 2024 | 06:05 PM
Lawandorder
Banned Scam/Spammer
look closer, sir. He has an LS6 valley cover with internal valve. It SHOULD NOT be there.
moreover, even if it was a 2001 - 2003, it’s in the wrong place. 😂😂😂
Old Apr 2, 2024 | 06:09 PM
Smoken1's Avatar
Smoken1
Only 04 valley covers had the PCV valve built in
Refer back to the video you posted
Old Apr 2, 2024 | 06:11 PM
Lawandorder
Banned Scam/Spammer
SIR LOOK AT THE PHOTO. he has an ls6 valley cover. 🤪🤪🤪🤪🤨
Old Apr 2, 2024 | 06:46 PM
Smoken1's Avatar
Smoken1
LS6 PCV valve and part #, as you can see it is not part of the valley cover
Old Apr 2, 2024 | 06:51 PM
Lawandorder
Banned Scam/Spammer
youre killing me. Let me try and break this down for you:
Z06: ls6 valley cover has internal pcv. No external valve.
c5 2004: has ls6 valley cover. No external valve.
the photo above is an LS6 VALLEY COVER which has an internal valve. THUS, it should NOT have an external valve.
moreover, that valve is in the wrong spot. And it’s not attached to the long hose that goes around the entire motor if this was a 2001-2003 car which it’s clearly not.
you are wrong and confused.
Old Apr 2, 2024 | 07:00 PM
Smoken1's Avatar
Smoken1
Not all LS6 valley covers have an internal PCV valve. The parts diagram I posted IS from the LS6 section of the parts diagram for the 01-03 model years
The video you posted shows that there are 2 different LS6 valley covers
Old Apr 2, 2024 | 07:17 PM
captain vette
I think that You are wrong and confuse
Old Apr 2, 2024 | 10:10 PM
Lawandorder
Banned Scam/Spammer
You guys go ahead and blow your crankcase 😂😂
Old Apr 2, 2024 | 10:45 PM
aaronc7's Avatar
aaronc7
Old Apr 2, 2024 | 11:08 PM
Smoken1's Avatar
Smoken1
Thanks for the photo
Old Apr 3, 2024 | 08:35 AM
captain vette
yeah some guys here think they know everything and they will never change their mind even though they know they are wrong. Thank for the pic.
To PCV Issues
Old Apr 3, 2024 | 09:10 AM
Jakeonio's Avatar
Jakeonio
Okay, so yeah I’m confident I have it routed correctly but the direction of flow is the concern. I placed an external PCV inline with the intake manifold but I still blew my seals, so I’m very confused. I used one that was flared on both ends so I could use regular tubing. I can’t find any tubing for one of those PCV’s pictured. Does anyone have a source for getting that? This was my temporary “fix” that blew my crap up. Don’t mind the stupid plastic key on the clamp. You can also see my valve cover gasket popping out.
Old Apr 3, 2024 | 09:11 AM
lucky131969
You gotta love the way a narcissist doubles down though
Old Apr 3, 2024 | 12:16 PM
captain vette
it’s well routed but you missed the the pcv valve on the hose that goes in the intake manifold
