Window up/down randomly stops working
Old Apr 8, 2024 | 01:47 AM
2001-Z06_Mike's Avatar
2001-Z06_Mike
Default Window up/down randomly stops working
My left drivers side window is now getting stuck going down or coming up at random.
What part do I need to fix this on a C5 Z06.
Could this be the door panel switch failing or is it more likely the window actuator? All the buttons on the door control panel seem to function fine.
Old Apr 8, 2024 | 09:49 AM
smitty2919's Avatar
smitty2919
Look at the wiring that passes through the door. It is inside the accordion boot you see when opening the door. There is a plug behind the footwell panel where the hood pull lever is. You can pull that panel off and should see it tucked up there. Sometimes the connections can get loose.
I wiggled mine and it started working again lol.
