Knock sensor woes
Old Apr 14, 2024 | 02:36 PM
Yoko-Chan's Avatar
Yoko-Chan
Default Knock sensor woes
Hello friends,
back in 2021 I had to change my knock sensors and then they went out again a couple months later and I took it to a mechanic and he changed the sensors and valley cover gasket and it was fine for awhile but now my sensor triggered the check engine light again and I’m wondering if maybe there’s a known issue that has an easy fix. I plan on changing the sensor on Friday so any advice would be helpful.
thanks for your time,
- Will
Old Apr 14, 2024 | 09:38 PM
link9a's Avatar
link9a
First you need to check the code. ...but I can tell you from now. Don't buy AC Delco brand because they are defected from the manufacturing ... Buy the NAPA knock sensor with NAPA harness are good to go ...
Old Apr 14, 2024 | 11:17 PM
Yoko-Chan's Avatar
Yoko-Chan
Thanks for the heads up, I'll order the napa ones
Old Apr 15, 2024 | 07:25 PM
lucky131969's Avatar
lucky131969
Torquing to the service manual spec is imperative.
To Knock sensor woes
