Dyno Procedures
Old Jan 29, 2003 | 09:44 PM
Big Al's Avatar
Big Al
Default Dyno Procedures
I have to have my car emmisions tested this year to get plate renewal. They use a 2 wheel roadwheel dyno. I know it must be able to be done as I have seen tuners use them, but now I need to know. I would think there will be faults stored when run on dyno as the computer will see no front wheel speed.
What should I do before the state employee puts my car on the dyno?
Is shutting traction control off enough? Will there be error codes and just restart the car to clear?
Old Jan 29, 2003 | 11:30 PM
enloe's Avatar
enloe
Default Re: Dyno Procedures (Big Al)
No problem. Just turn off the traction control, or have the driver/tester do it. No codes should be stored as a result of the test. The car is smart enough to know what is going on. Do a search on the forum to see how to check and clear codes if you do not already know how to do it. You do not need any special equipment, just the buttons on the dash.
