Suspension height adjust with 18" square set up
Old Apr 23, 2024 | 04:43 PM
68Malibu383's Avatar
68Malibu383
Default Suspension height adjust with 18" square set up
Have an '03 Z06 that I ocassionally track at VIR. Previous owner dropped the car all the way down on factory bolts with factory sized tires (the rubbers below the leaf springs are still in place). Car had no rake and experienced front lift around 120 mph and up. I raised the front 0.75" and the rear 1.25" That eliminated the problem.
I now have 295/35 18s all the way around, which raised the front end 0.4". I wanted to lower the front in order to retain the rake. I was only able to turn the front bolts 2.5 turns counter clockwise before they bottomed.
From what I have read, a car dropped all the way down on factory bolts, will have poor handling due to suspension bottoming. If the front bolts are 1/2 turn from bottom, and the factory rubbers are still in place, is that too low for proper suspension function? Any idea what the range would be to still retain decent handling (ie, 2, 3, 6 turns of bolt from bottom)?
My other option would be to raise the front back to where I had it, then raise the rear to get the rake back.
Thanks for input!
Old Apr 24, 2024 | 07:56 AM
Bobbo76's Avatar
Bobbo76
Veteran: Canadian Forces
I would suggest posting this in the autocross/road racing forum. I'll have a look later today and see if I still have my alignment specs. I'm on coilovers so that may make a difference.
Old Apr 24, 2024 | 05:00 PM
ipuig's Avatar
ipuig
St. Jude Donor '09
Thanks for input!
I think restoring the front to rear rake by lifting the rear is your best course of action. Read this, there is a section in this report that addresses how ride height affects lift and drag.
File Type: pdf
To Suspension height adjust with 18" square set up
