Hi guys .. when l try to buy knock sensor harness from NAPA it's show 2 harness the both have the same interchange number 730_6778. But different part number one it's say (( can be used as a Detonation knock )) so which one lwill go with ? Or do l need to go with AC Delco ?
I used this one. Has been working for 18 months. It seemed to be made well. Only $12.99. Note don't buy the sensors that are offered, they are garbage.
I also bought the one linked above from Amazon. It's only been two weeks, but working great, and I liked how the rubber grommets really went on tight, inspiring confidence it could keep moisture out of the well.
Yeah, I put Doorman sensors on mine recently. One was bad. Sure was fun removing the intake again to put another sensor on.
See if this works.
Knock Sensor Wiring Harness | for Chevy Suburban Silverado Avalanche Tahoe, GMC Sierra Yukon, Cadillac & More GM Vehicles | Replace# 12601822, 917-033 https://a.co/d/2ariWjx
