HELP! Leaf spring misaligned
Old May 2, 2024 | 04:08 PM
Yoko-Chan's Avatar
Yoko-Chan
Default HELP! Leaf spring misaligned
Installing Z06 springs and passenger front doesn’t line up but driver front is fine. how do I fix this?
Old May 2, 2024 | 05:58 PM
Chevy Cust Svc's Avatar
Chevy Cust Svc
Our team would like the opportunity to learn more about the misalignment on your Corvette and investigate ways we can potentially assist. When you get the chance, please send us an email to socialmedia@gm.com. Be sure to include your Username and Forum name in the subject line, then provide additional details about your experience in the body of the email. We look forward to your contact.socialmedia@gm.com
Old May 2, 2024 | 06:35 PM
lucky131969's Avatar
lucky131969
Did you use a transverse spring compressor?
Old May 2, 2024 | 07:13 PM
Yoko-Chan's Avatar
Yoko-Chan
no, I watched the scruffs garage video and he didn’t use one
Old May 2, 2024 | 07:40 PM
heggsc5's Avatar
heggsc5
Been a while since I pulled the OEM spring, what exactly are we looking at in your picture besides one of the brackets? If that's the spring going into the bracket, which I think it is, there's nothing on the other end to line up...the spring should go a long ways past that bracket. Did you maybe buy a broken spring? Maybe more info or better pictures?
Old May 2, 2024 | 07:54 PM
G_Loc's Avatar
G_Loc
What the heck? Broken forum bot?
Old May 2, 2024 | 08:04 PM
Yoko-Chan's Avatar
Yoko-Chan
I wasn’t sure if there was anything else I’d need to take a picture of. My new leaf spring lines up with only 1 bracket and im wondering if it’s just fully decompressed from having sat. After some digging I had found another forum member had the same issue and decided to jack up the right and left sides to compress the spring and guide it into the right spot. Im currently prepping for that.
it looks like I’m getting them closer but time will tell!
Old May 3, 2024 | 09:01 AM
lucky131969
...in that case you are fine.
Old May 3, 2024 | 09:38 AM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Due to the amount of arc in the spring it needs load on both sides to get the pads to line up correctly. As the spring relaxes the rubber mounts get closer to the center.
Old May 3, 2024 | 01:35 PM
Yoko-Chan's Avatar
Yoko-Chan
I ended up getting it in, it was just a little sketchy.
Old May 3, 2024 | 02:19 PM
heggsc5's Avatar
heggsc5
Ahhh I see, yeah the spring is basically a "frown" shape and the weight of the vehicle flattens it out, so you need to compress it to get it in (or drop lower control arm on the hub end). You got it! You'll find the rear spring is much easier and just drops right out because it runs under the control arms instead of on top. With longer bolts, it'll be completely unloaded when jacked up haha
To HELP! Leaf spring misaligned
