Oil Pressure Sensor issue
Old May 13, 2024 | 06:26 PM
rovercash's Avatar
rovercash
Default Oil Pressure Sensor issue
I know this has been discussed quite a bit but couldn't quite find the issue I'm experiencing. Previously had an oil pressure sensor go out. Gauge showed maxed out. Finally had it replaced a few years ago and it went out again. Maxed out again. Then after a month or more since it went out, when I first take the car out, I'll get a service engine soon light and the gauge will start going to low and then bounce back up. It will do this a few times with the service engine light coming on and off. Then it stops and just stays at max like normal. Is it just the bad sensor causing this or should I be worried about any other potential issue? 2002 z06. Thanks
Old May 13, 2024 | 07:16 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
May be a wiring issue…these sensors don’t operate by magic !!…the 3 wire sensor has a 5 volt reference, a signal wire and a ground…don’t know your electrical expertise so won’t comment…you should ALWAYS verify wiring integrity before replacing parts.
