CAGS solenoid thread pattern and questions
Old May 14, 2024 | 09:43 AM
G_Loc's Avatar
G_Loc
Default CAGS solenoid thread pattern and questions
Can someone confirm if the CAGS solenoid thread pattern is M20x1.5? Secondly, how much transmission fluid is up there and can I jam a temperature sensor into the opening without causing any issues?
Old May 16, 2024 | 04:56 PM
hmhaga's Avatar
hmhaga
The skip shift solenoid thread is M20x1.5
https://www.z06vette.no/2023/10/skip...elete.html?m=1
Old May 16, 2024 | 04:59 PM
G_Loc's Avatar
G_Loc
Awesome, thanks for confirming! I searched high and low for that info. Solenoid will be removed tonight and replaced with a temperature sensor (I know the location is not ideal, but this is temporary)
Old May 16, 2024 | 05:15 PM
hmhaga's Avatar
hmhaga
Sorry, your information is correct, M20x1.5, which is the thread pitch of the Subaru oil drain plug I used. I think you will get quite a delay and or offset in your temp readings in this location, as I guess there is only a limited oil mist from the gears in this location.
I've corrected my first reply, in case others read this thread.
Old May 17, 2024 | 09:48 AM
G_Loc's Avatar
G_Loc
Yea figured the reading wouldn't be accurate, but I wanted a temporary solution until I got the proper 6AN adapter for my cooler set up. In any case, turns out the adapter I have on hand is 1/2x1.1.25 or something, so it didn't fit. Guess I'll be ordering the correct adapter plus a plug for when I remove the solenoid altogether. Thanks for the help!
To CAGS solenoid thread pattern and questions
