How to remove the door panel access plug? My Window is stuck
The small black plastic piece on each door? they're super glued in it seems. Do i just rip it out?
I have to remove it in order to try the hammer trick to fix my frozen stuck window.
The following 2 users liked this post by Missileboy:
rrwirsi (05-14-2024),
yellow2007 (05-14-2024)
this driver side one is definitely glued. how should i proceed? just pry/rip it out?
the pass. side one fell out many years ago, and i had to do the hammer trick on it a few times to unfreeze the window. now its the driver's side
If it is glued, then you might want to try a little heat to soften up the glue (won't work on all glues) and pry it out carefully. You can get news one from Mark @VetteNuts
C5 Interior Door Panels and Components (vettenuts.net)
