Replacement water pump model help
Old May 14, 2024 | 09:30 PM
yellowGS's Avatar
yellowGS
Default Replacement water pump model help
Looking for some guidance on a replacement water pump. I’ve found two AC Delco models that are supposed to fit the C5, 252-846 and the 251-744. For some reason the 744 model is quite a bit more expensive.
thanks for any help
Old May 14, 2024 | 11:51 PM
chain_5001's Avatar
chain_5001
The less expensive part is an overseas produced part. The more expensive part is/was made in North America.
Old May 15, 2024 | 05:16 AM
yellowGS's Avatar
yellowGS
Thanks!
Old May 15, 2024 | 08:30 AM
lucky131969's Avatar
lucky131969
Originally Posted by yellowGS
Thanks!
Also remember that a true 97-2003 LS1 water pump may no longer be available..unless you find NOS. 2004+ versions have a different thermostat housing and thermostat. So the 2004+ pump will bolt right up, but your 97-2003 thermostat/housing will not.
PM Sent
Old May 15, 2024 | 08:34 AM
yellowGS's Avatar
yellowGS
PM Sent
Thanks for that information, I have an ‘03, so I guess a new thermostat & housing are also on the list
To Replacement water pump model help
