Coolant odor
Old May 17, 2024 | 12:08 PM
RPGR90s's Avatar
RPGR90s
Default Coolant odor
2000 Convertible with 70k. I will intermittently have a faint coolant odor after returning from a drive, car in the garage.
I disconnected the tank to inspect underneath and I don't see any weeping, leaks, etc. In fact, the tank looks almost like new. I also don't see any drips on the floor or coolant weepage anywhere on the engine.
Am I missing an obvious area to look at?
Thanks very much,
RPGR90s
Old May 17, 2024 | 02:45 PM
lucky131969's Avatar
lucky131969
Sure. Radiator, hoses, thermostat housing/water pump, engine block, heater core/connections.
Since you removed the tank, make sure you burp the system.
Old May 17, 2024 | 02:51 PM
G_Loc's Avatar
G_Loc
Is the smell present inside the car or outside?
Old May 17, 2024 | 03:25 PM
redzg's Avatar
redzg
Original radiator? They are noted for have issues with the driver's side tank cracking near the hose connection. Difficult to see, as the tank and hose connection are covered by the upper radiator shroud, but if yours has cracked like mine a good visual check of the area after a good run will show evidence of coolant, either wet or evaporated dry.
Old May 17, 2024 | 04:16 PM
Red86Cfour's Avatar
Red86Cfour
Are you having to add coolant? If you smell it inside I'd say heater core. Outside, cracked radiator tank. My c6 radiator lasted about 80K, and water pump a few thou after that.
Old May 17, 2024 | 04:47 PM
30rpm's Avatar
30rpm
Old hoses is my bet
Old May 17, 2024 | 05:37 PM
RPGR90s's Avatar
RPGR90s
It is only present outside the car.
Old May 17, 2024 | 05:39 PM
RPGR90s's Avatar
RPGR90s
I'm not having to add coolant.
I think I'll put a fresh piece of cardboard on the floor. Maybe my old one is mixed with other oils, etc. and I'm not seeing any leakage.
Old May 17, 2024 | 07:10 PM
mmartinez's Avatar
mmartinez
I had the same thing going on many years back, replaced the coolant tank pressure cap which resolved the problem.
Old May 18, 2024 | 06:38 PM
RPGR90s's Avatar
RPGR90s
Coolant tank cap. Never thought of that. I'll go that route first.
Thanks very much!
Old May 18, 2024 | 08:47 PM
Smoken1's Avatar
Smoken1
It should say 18psi on it
Old May 19, 2024 | 08:10 AM
VERYSOON's Avatar
VERYSOON
RPGT
I had the same issue a few years ago. I could only smell the coolant when I would get out of the car to open my gate. Took a while, but found the culprit. It was the gasket (actually it's an O ring) on the thermostat housing!!
Check that !!!
VERYSOON
Old May 20, 2024 | 06:27 AM
redzg's Avatar
redzg
Good point! Changing from 14 to 18 really helped point out that my tank was cracked.
Old Jul 1, 2024 | 08:48 AM
RPGR90s's Avatar
RPGR90s
Follow up:
I think what I was smelling was power steering fluid. My car has the optional power steering cooler. I bought a new thermostat housing o-ring and lifted the front of the car to empty the radiator fluid.
Pulled the thermostat and the original o-ring looked fine but replaced it anyway. While underneath the car, I noticed the two rubber power steering fluid lines that run to the cooler were leaking. There was enough fluid to coat the front subframe.
Cleaned all that up, replaced the lines and have taken the car out twice with no noticeable odors of any kind.
Thanks for the help, but I think it was PS fluid all along.
RPGR90s
To Coolant odor
