Going to standalone. Can I remove everything?
Old May 20, 2024 | 03:34 PM
99FRC Newb's Avatar
99FRC Newb
Default Going to standalone. Can I remove everything?
Hi everyone!
I am moving over to a Holley Dominator EFI soon. I'm not planning on using the stock gauges. Planning on swapping to manual brakes and manual steering. Is there any reason for me to keep any of the stock modules/wiring in the car? I don't think there will be anything left for them to control.
Old May 20, 2024 | 06:25 PM
mmartinez's Avatar
mmartinez
You still need a PCM and BCM, the PCM is still required to provide pulses to fire the coil packs unless you are installing a distributor, which can be done.
Old May 20, 2024 | 07:19 PM
99FRC Newb's Avatar
99FRC Newb
The Holley Dominator can control coil packs.
Old May 20, 2024 | 08:36 PM
mmartinez's Avatar
mmartinez
My bad, I thought it was just a EFI system, so it must have inputs from the crank and cam sensors?
Old May 21, 2024 | 09:14 AM
feeder82's Avatar
feeder82
The Holley systems can control most systems depending on the one you buy. Engine control, trans, boost, nitrous.
Old May 21, 2024 | 10:58 AM
jcgunn's Avatar
jcgunn
BCM for doors and locks. RFA for key fobs?
Old May 21, 2024 | 11:43 AM
99FRC Newb's Avatar
99FRC Newb
No worries! I should have posted a link to it. Dominator EFI (holley.com)
It is a wild system. Something like 40+ inputs and 30+ outputs.
99FRC Newb's Avatar
99FRC Newb
THAT is something I did not think of. Probably need the BCM for the windows too, right?
Old May 21, 2024 | 12:29 PM
jcgunn's Avatar
jcgunn
When my BCM went out (short in accordian pack) the power windows did all kinds of wacky stuff!
Old May 21, 2024 | 01:16 PM
Supercharged111's Avatar
Supercharged111
When you say manual brakes, are you talking about a setup with 2 master cylinders and a balance bar?
Old May 21, 2024 | 08:06 PM
99FRC Newb's Avatar
99FRC Newb
Something like this, but bigger so it can actually handle my C7Z iron brakes.
Old May 21, 2024 | 10:42 PM
lucky131969's Avatar
lucky131969
Old May 22, 2024 | 11:25 AM
99FRC Newb's Avatar
99FRC Newb
Originally Posted by lucky131969
THANK YOU! That was insanely informative.
I am very curious about the "Geo Corvette" though.
Old May 22, 2024 | 07:54 PM
lucky131969
The electronic service manual from 15 years ago had a heading "Chevrolet/Geo", and then the Model of the vehicle.
Old May 23, 2024 | 09:52 AM
99FRC Newb's Avatar
99FRC Newb
Ah, that makes more sense. I wasn't sure if they sold the Corvette overseas under the Geo brand or something.
To Going to standalone. Can I remove everything?
