How to keep antenna down while streaming
Old May 22, 2024 | 11:18 PM
ztheusa's Avatar
ztheusa
Veteran: National Guard
Default How to keep antenna down while streaming
Is there a fuse that I can pull.............or has someone mounted a switch somewhere?
I almost always stream now and don't need/want my electric antenna to work on my 2004 Roadster.
Is there some easy way......clever way......to temporarily disable the antenna motor?
TIA!
Old May 22, 2024 | 11:28 PM
jdmvette's Avatar
jdmvette
Night Owl for life
There's probably a fuse but I imagine you can also unplug it via the outboard rear tail light.
Old May 23, 2024 | 08:30 AM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
Yep. The fuse is located in the passenger footwell. I pulled mine years ago as I didn’t like the radio controlled toy car look. I upgraded to a double din head unit and either connect my phone or use Bluetooth. I still get good radio r3ception as well.
Old May 23, 2024 | 09:06 AM
LWSZ06's Avatar
LWSZ06
Here is some info
https://www.corvetteforum.com/forums...na-issues.html
To How to keep antenna down while streaming
