No electrical power at all
Old May 27, 2024 | 02:20 PM
Donald Murphy's Avatar
Donald Murphy
2nd Gear
Default No electrical power at all
New battery but no power to anything at all. Car won't jump or even trickle charge.
Old May 27, 2024 | 08:27 PM
Dads2kconvertible's Avatar
Dads2kconvertible
Wire disconnected somewhere. Fuse blown? Grounds?
Need information from you for the best opportunity to get good answers Donald. What car? Ran fine yesterday, today dead? Pulled out of a lake where it's been sitting since 1997?
Old May 27, 2024 | 09:36 PM
redzg's Avatar
redzg
Side terminal battery? Double or even triple check that the battery and cable terminals and even the bolts are good and clean, then assemble with the bolts quite snug. References indicate 11 lb/ft bolt torque. Don’t know I can force myself to go that high, but I have experienced what I thought were tight bolts causing exactly the same symptoms.
Old May 28, 2024 | 05:58 AM
Moved to C5 Tech.
Old May 28, 2024 | 12:23 PM
mmartinez's Avatar
mmartinez
Sounds like it's time to pull the DVM and perform some voltage checks, as mentioned previously check your battery terminal connections.
Old May 28, 2024 | 09:47 PM
Donald Murphy
2nd Gear
Ran fine until battery got low and when jumped it the alarm went off. Had a warranty on the battery so got a new one but I think the antitheft is locking everything out now. Side terminals are clean. Have tried both keys but still nothing. How can I reset anti theft if that is it?
Old May 28, 2024 | 10:52 PM
Dads2kconvertible
Start with the service manual information for your car. This one covers early models.
File Type: pdf
Old May 28, 2024 | 11:43 PM
mmartinez's Avatar
mmartinez
Anti theft will not allow the engine to crank over, but you should still have the gauges and indicator lights come on, the radio should work, anti theft will not shut down all power.
To No electrical power at all
