Headlight issue
Old Jun 8, 2024 | 05:24 PM
VTSS's Avatar
VTSS
Default Headlight issue
So I’ve been reading all the headlight issue posts but I haven’t found one that fits my issue.
The headlights work and function properly 100% of the time when the vehicle is off. When the car is running the twilight feature and headlight switch generally does not work to open the headlights (only works like 1 out of every 10 times). The headlights will turn on but will not open. I normally have to turn the car off at a stoplight and then use the switch to open them. I’m stumped on this one, any help is appreciated.
Old Jun 8, 2024 | 09:10 PM
TonyCorvette_'s Avatar
TonyCorvette_
C5 MFS Guru
Looks like there’s a relay, BCM, and light sensor in that circuit. Or you can just keep twilight off.
Old Jun 8, 2024 | 09:13 PM
VTSS's Avatar
VTSS
Originally Posted by CorvetteHeadz
I had a very similar issue. Turned out to be a loose battery connection. Make sure your posts are clean, contact is good and they tightened down. Drove me insane for months.
The negative was like a quarter turn loose so I tightened it and it worked the first time. Hopefully that continues, thanks!
To Headlight issue
