04 zo6 backfiring ?
Old Jun 15, 2024 | 07:25 PM
glas car's Avatar
glas car
Default 04 zo6 backfiring ?
I have a 04 z . low milage. 25k, just did oil change, clutch flush and serviced the black wing cai, now getting some backfiring , mostly when letting off the throttle but this car has never done that before? Really haven't looked it over yet ( will start tomorrow ) just wondering if anybody had any ideas? Thanks !
I put fresh gas in it but there could be some residual storage fuel in there.
Old Jun 15, 2024 | 07:59 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Maybe you over oiled your Blackwing….this can affect your MAF sensor…if you have a scan tool check your fuel trims and also check your MAF sensor…should read around 5.7 to 6 grams/second at hot idle…other than this there are many causes but start with cleaning the MAF sensor…that is the only thing you’ve done that may have caused this…when I had my 01 and oiled my Blackwing I always would clean the MAF after running the car for awhile.
Old Jun 16, 2024 | 12:27 AM
Moved to C5 Tech.
Old Jun 16, 2024 | 02:31 PM
glas car's Avatar
glas car
thanks for the reply C5 Diag , I think that's is exactly whats wrong , I my have gotten a little over zealous with the B W oil! Haven't had a chance to work on the car yet but I'm sure that's it! I will post what happens ! Thanks again!
Old Jun 16, 2024 | 02:41 PM
C5 Diag's Avatar
C5 Diag
No problem !!…my ‘08 has a Callaway Honker filter similar to yours and I oil it very sparingly !!…if you have an air compressor I’d blow some of that oil off of it first.
Old Jun 16, 2024 | 03:46 PM
glas car's Avatar
glas car
Will do ! thanks!
Old Jun 16, 2024 | 05:04 PM
Markolc1981's Avatar
Markolc1981
Are you talking about deceleration pops?
Old Jun 16, 2024 | 06:45 PM
glas car's Avatar
glas car
No, this is something that just started after doing a little PM, I really think its the BW filter oil in the MAF, thanks!
Old Jun 17, 2024 | 11:48 AM
3sACROWD's Avatar
3sACROWD
Sounds like you have a good line on the issue. The other possibility is your connection (air bridge) between the MAF sensor and the intake isn't sealed. On occasion mine slips off and I get a rough idle and backfires due to unmetered air getting in..
Old Jun 17, 2024 | 01:39 PM
glas car's Avatar
glas car
thanks , that is also possible, will know on Wednesday when I can work on the car and will post outcome! thanks again !
Old Jun 17, 2024 | 11:28 PM
bluestreak63's Avatar
bluestreak63
When you start it up, take a listen to the exhaust. Are you getting any inconsistent/random drum beat sounds out of one side?
Old Jun 19, 2024 | 07:09 PM
glas car's Avatar
glas car
Well I got to work on the car today, pulled air filter and cleaned it of any oil that might be the problem , cleaned MAS , it did not look dirty but cleaned it anyway, I did not clean TB but it is spotless! car still letting out little backfire at idle, not at start up ,just after a little ride.
Next step will be the scanner, see if there are any codes! Thanks for the suggestions , I will let you guys know what happens ! Thanks again!
PS bluestreak63 did not hear any random drum beat sounds out back at startup or after the ride just the backfire!
Old Jun 23, 2024 | 10:01 PM
Mc556's Avatar
Mc556
Normally it’s an air leak after the MAF sensor. Lose or not fitted coupling etc. Should be a easy fix
Old Jun 25, 2024 | 09:14 PM
glas car's Avatar
glas car
Just to let you guys know, got the car running back to normal, Changed out plugs and wires and she running great! The wires didn't look real bad but I changed them anyway, they where old!
Thanks to everyone who replied , really appreciate the help !
Old Jun 25, 2024 | 10:38 PM
bluestreak63
Glad to hear you got it sorted. Was the popping just when you let off throttle? Did it pop/backfire when you started out from a stop? I’m chasing an issue with backfiring from starting out, say from a stop sign or a red light. Also, the passenger side exhaust seems to have random bass drum beat. And it maybe just me but when I first start it, it seems the passenger side, where the sound is coming from, is not as warm as it warms up compared to the drivers side exhaust. The air coming out the exhaust I mean.
Old Jun 26, 2024 | 08:04 PM
glas car's Avatar
glas car
Bluestreak63 , my car was just letting out some backfires at idle, scanner said it was misfire on #4and#5, everything else was normal. I think the thing to do is get the scanner on it and go from there, good luck hope you can get it running right soon!
To 04 zo6 backfiring ?
