quick question
Old Jun 19, 2024 | 10:58 PM
Chad Bergeron's Avatar
Chad Bergeron
Default quick question
i just bought a used block and i have to get the cylinders bored as there was some rust and light pitting on the sleeves. anyway , the machinst sai they make 3 sizes over stock, 10 over, 20 over and 30 over. im not a mechanic and i dont speak the language so i dont really know for sure what that means. my question is, depending on how much he has to bore, what size piston would i need for each size? thanks in advance.
Old Jun 19, 2024 | 11:17 PM
Mr. Black's Avatar
Mr. Black
No Hostility Be Happy
Aluminum block?
Factory aluminum blocks don't get bored out per say. They can be oversized a smidge but not much.
If it's iron block that is a whole different ball game.
Of course there are exceptions to all of this depending on how much money you have.
Old Jun 20, 2024 | 08:06 AM
Chad Bergeron
aluminum block.
Old Jun 20, 2024 | 09:20 AM
03tripleblack's Avatar
03tripleblack
2024 C5 of the Year Finalist - Unmodified
To answer your question..
"10 over" means the machinist bores the block/sleeve 0.010" larger than stock. The result is that you have to buy "10 over" pistons and rings to match.
If it was my block, I'd pick the smallest overbore that's required. Leaves some room for next time and the larger the overbore....results in thinner sleeves which isn't great for durability or heat changes.
Old Jun 24, 2024 | 02:49 PM
Moved to C5 Tech.
Old Jul 2, 2024 | 02:09 PM
kh400's Avatar
kh400
The problem is most of the sleeves installed at the factory are not properly centered, making the sleeve thin on one side and thicker on the other. So, you can't really bore it. Best to have a machine shop install new std. bore sleeves.
Old Jul 3, 2024 | 07:42 AM
ipuig's Avatar
ipuig
St. Jude Donor '09
Maximum overbore for an LSI is .010"; there is a cylinder boring and honing procedure in the service manual. I suggest you have whomever is going to perform this work familiarize themselves with the service manual's boring and honing procedure.
Old Jul 4, 2024 | 01:10 PM
lionelhutz's Avatar
lionelhutz
There are oversize pistons that are less than 0.010" oversize. 0.005" oversize is a popular piston size if that will work.
To quick question
