C5 Bushings Problem
Old Jun 20, 2024 | 06:51 PM
Jasin's Avatar
Jasin
Cruising
Default C5 Bushings Problem
I currently bought a c5 with bad sway bar bushings and also saw i have a hotchkis sway bar kit on it front and rear and have had a hard time looking for the correct bushings to replace and none of them would seem to fit correctly i have done this 3 times and none seem to work if anyone would be willing to help knowing where to purchase and find the correct ones it would be a great help since this is starting to get very frustrating
this is the current rear bushing that is split in half just to give a idea of what i need
rear
front
Old Jun 21, 2024 | 06:32 AM
Moved to C5 Tech.
Old Jun 21, 2024 | 07:03 AM
lucky131969's Avatar
lucky131969
Have you measured the sway bars and reached out to Hotchkis directly?
Old Jun 21, 2024 | 07:35 AM
Jasin's Avatar
Jasin
Cruising
the rear sway bar is a one inch bar
the front is a 1 1/4 bar
Old Jun 21, 2024 | 07:45 AM
lucky131969
Yeah..I know. Have you reached out to the manufacturer?
Old Jun 21, 2024 | 08:36 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Or, either Energy Suspension or Prothane..........
Old Jun 21, 2024 | 01:50 PM
Jasin's Avatar
Jasin
Cruising
i have reached out to the manufacturer multiple times and have had no response back i’ve bought energy suspension and prothane ones as well and both did not fit that’s why i’m asking for help if anyone is willing to send a link of the correct ones needed
Old Jun 22, 2024 | 07:12 AM
leadfoot4's Avatar
leadfoot4
"Did not fit" the sway bar brackets on the car, or fit snugly around the OD of the sway bars?
Old Jun 22, 2024 | 09:10 AM
Jasin's Avatar
Jasin
Cruising
did not fit on the bar and bracket as well
To C5 Bushings Problem
