1 Headlight won't open
Old Jun 21, 2024 | 12:00 PM
keith ragan's Avatar
keith ragan
Default 1 Headlight won't open
I recently purchased a 2000 coupe, the previous owner had the rh headlamp motor replaced before I bought the car. it will not open unless I open the hood and turn the **** a 1/4 of a turn manually, it then opens just fine. Since there is not a motor stop switch what can I do to repair this problem? The dealership that replaced the motor for the previous owner said there is not much they can do about it. TIA
Old Jun 21, 2024 | 12:34 PM
TonyCorvette_'s Avatar
TonyCorvette_
The plastic gear is the usual culprit; it is common to upgrade to bronze.
Old Jun 21, 2024 | 01:01 PM
rrwirsi's Avatar
rrwirsi
I sometimes have a similar problem with the passenger side headlight that I had the motor replaced with a GM new one. My fix is the same as yours, I back off (counter clock) the manual **** about 1/2 inch. I also cleaned the connection between the motor and control module and make sure the connection is tight.. I do not drive at night but do want the headlight to function properly should I need it. Each time I drive, at the end I open the headlight. Sometimes it takes a couple of on/off's to get the 'lazy' headlight to work. Maybe the issue is in the control module. Or maybe the **** tightens itself. Just another anomaly driving the C5.
Old Jun 21, 2024 | 02:27 PM
zz28zz's Avatar
zz28zz
The right side headlight was doing something similar when I bought my 2000 coupe. Installed the bronze/brass gears. Kit also had a metal plate that attached to the side of the actuator to help prevent flex in the plastic housing. 15+ years later, the headlights haven't missed a beat. Think they will out-live me.
Old Jun 21, 2024 | 08:11 PM
Ed Ramberger's Avatar
Ed Ramberger
Make sure all the plastic stops are there.
Old Jun 22, 2024 | 11:39 AM
grinder11's Avatar
grinder11
^^^^^^This absolutely^^^^^^. The stops put an increased load on the motor, which tells it (electronically) it has reached the desired location, and it's time to stop.....
To 1 Headlight won't open
