Driver side window doesnt go down - plastic bulges
Old Jun 21, 2024 | 03:20 PM
dragunov47's Avatar
dragunov47
Default Driver side window doesnt go down - plastic bulges
My driver side window wouldn't go down, I tried the hammer trick on a few occasions, nothing. Turns out I was hitting the middle bolt, should've hit the rear bolt. Once i hit the rear bolt, window went down after a few whacks. Fix only lasted 1 day and now it's stuck again. I can hear the "click" noise when ever i press down.
Also, when it was working, i noticed the inside plastic by my side mirror would swell / bulge up when the window was traveling UP. What could this mean?
My passenger side window also has gotten stuck on 3 separate time periods, however, the hammer trick fixed it and its been working for over a year now. But this driver side seems really messed up.
Old Jun 21, 2024 | 03:34 PM
mmartinez's Avatar
mmartinez
Sooner or latter the door panel has to come off to repair problems with the window regulator, and sometimes problems with the door module.
Old Jun 23, 2024 | 09:26 AM
rrwirsi's Avatar
rrwirsi
A thought. Maybe the connection between the door and body became loose. Reach into the accordion connector and make sue everything is tight fitting.
To Driver side window doesnt go down - plastic bulges
