You can rate a shaft at stress failure but this has little to do with engine output by itself. For example a good clutch and tire can rip the input shaft right out even if the engine only has low output. That is because kinetic energy can be stored in drivetrain/engine parts and rapidly released suddenly to explode a shaft or gearset. Keeping a performance transmission alive for general use applications such as daily drivers with normal street tires is more about how its used & treated than how much power the engine makes.
To answer your question in a practical sense, I've successfully maintained transmissions over 20 years rated around 300ft*lbs of torque at well near 800ft*lbs of torque output from an engine, thanks to slipping and elasticity in times of need and good driving principles. and I've seen many transmissions explode behind engines with 200ft*lbs of torque that are rated much higher because of sudden energy releases, or vibration issues, improper pinion angles, etc... you can easily ruin a transmission by incorrect drivetrain setting up angles, joints and flexibility.
If you have solid traction, the first thing you should break is the main shaft. But at that power range you're shooting for, I'll get a trans brace, the wide differential mount and function suspension that deters wheel hop. I wouldn't open the trans until you need to. you should enter the T56 physical limitation at around 750-800tq.
