Help!!!!
Old Jun 24, 2024 | 07:15 AM
97C5TW's Avatar
97C5TW
Cruising
Default Help!!!!
The stud from manifold to x pipe has snapped. Hitting it with everything from penetrating oil, heat, impact. The stud gradually kept snapping now it’s almost down to the manifold I really don’t want
to drill because I have done the whole drill out bullshit numerous times in the past and it never ends well. Drill doesn’t stay straight, or drill bit and/or tap breaks. Anyone have any advice? I don’t want to f**k up the flange and I don’t want to have to resort to taking the manifold out unless absolutely necessary. Thanks in advance. 1997 C5, 6 speed
Old Jun 24, 2024 | 08:35 AM
lucky131969's Avatar
lucky131969
Sounds like you have three choices....drill it out, EZ-out, or weld a nut on the stud. Most people that struggle with drilling/EZ-out suffer from poor position or impatience. The key to success is starting with a flat stud (cut or filed), use a center punch, and start with a small drill bit, and work your way up to either the next size, or required EZ-out size.
In all three cases, the best chance for success is with manifold removed from the car.
Old Jun 24, 2024 | 08:44 AM
sonicss33's Avatar
sonicss33
I agree with best results will be achieved by removing manifold and making repairs/extractions on the bench. It sucks but you knew the answer before you asked it. Good luck
Old Jun 24, 2024 | 09:26 AM
Dads2kconvertible's Avatar
Dads2kconvertible
stud gradually kept snapping now it’s almost down to the manifold...
You've tried everything to avoid it but you're at the "absolutely necessary" point now.
Old Jun 24, 2024 | 10:42 AM
redzg's Avatar
redzg
They make a c-clamp for exactly this situation. Is it optimum? No. Is it possibly adequate? Yes.
Also, when I’ve been in a similar situation in my past (admittedly with a SBC), the manifold to head bolts were just as argumentative. If you go that route, be very cautious.
https://www.summitracing.com/parts/aph-8027?seid=srese1&gclid=Cj0KCQjwsuSzBhCLA RIsAIcdLm7U6QFF70jHFgbhUaEmdJLsLLj2gh6ek MVi7IaG-eGyj7V5Sc-vS3IaAgmqEALw_wcB
To Help!!!!
