a/c drain line blocked
Old Jun 28, 2024 | 03:39 PM
actmyage's Avatar
actmyage
Cruising
Default a/c drain line blocked
A/C drain line blocked, water coming in on pass. side floor. Where is drain located?
Old Jun 28, 2024 | 04:35 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
You may have a clogged cowl vent “udder”…why do you think the AC drain line is plugged ??…you don’t see a puddle of water underneath the car with AC running ??
Old Jun 29, 2024 | 09:14 AM
yellow2007's Avatar
yellow2007
https://youtu.be/HeAUxEnNXe4?si=VuP_i09tanvm3auP
As usual.
Old Jul 5, 2024 | 04:31 PM
actmyage's Avatar
actmyage
Cruising
Information was perfect, problem solved. Thank you very much.
To a/c drain line blocked
