Knock Sensor - Check Engine
Old Feb 1, 2003 | 06:47 PM
cigar's Avatar
cigar
8th Gear
Default Knock Sensor - Check Engine
'99 vert-My check engine light is coming on due to an intermittent failure in the rear knock sensor circuit. It commonly fails during warm up at around 1900 RPM. It doesn't seem to matter if the engine is under load or not. Has anybody else had this failure? I'm thinking of just replacing the sensor and while I'm at it putting on the LS6 intake.
Any information from someone with experience would be greatly appreciated.
Thanks a ton guys!! Yes, the code is P0327 and the thread given below is excellent. Of course, I wish their were a simple pill. Now I think that I will go ahead and put on the LS6 intake and try to fix this problem at the same time. I am fairly certain that there is no real damage but the everpresent indicator light is annoying.
Thx Again:thumbs:
[Modified by cigar, 5:18 PM 2/2/2003]
Old Feb 1, 2003 | 11:39 PM
EuG's Avatar
EuG
Default Re: Knock Sensor - Check Engine (cigar)
Are you getting code P0327?
I get the same thing. :sad:
I just had both knock sensors replaced and I got this code ones again
Also check out this post **P0327 code what does it mean???
[Modified by EuG, 11:40 PM 2/1/2003]
Old Feb 2, 2003 | 07:00 AM
vettenuts's Avatar
vettenuts
Default Re: Knock Sensor - Check Engine (EuG)
Totally from memory, and I may have this wrong, but I seem to think there was a TSB on the rear sensor getting wet and corroding or something. Might want to check "alldata" web site to see if something is listed.
Old Feb 2, 2003 | 08:22 AM
Tom Hall's Avatar
Tom Hall
Default Re: Knock Sensor - Check Engine (vettenuts)
I get the 0327 and 0332 codes. Replaced both sensors and I still get the codes. I never know when it will come on. It happens at different times, Start up cold or hot and sometimes just going down the road at 50mph. I never had this before with the 422 until I got it back this time from having the engine repaired. I shut the codes off at the track or I get 9.9 degrees of KR. The wiring looks OK. I guess It's the noisy engine. I would like to find an answer to this problem. I have done the TSB, Silicone and Foam off the bottom of the intake. :confused:
Old Feb 2, 2003 | 09:34 AM
davidmax's Avatar
davidmax
Default Re: Knock Sensor - Check Engine (Tom Hall)
If an intermitent misfire comes up I just go through the reset procedure through the D.I.C and blow it off.You may want to try 02 simmulatores slight possibility they may ignore an irrattating situation that causes 0 damage just a pia.Dave S.
To Knock Sensor - Check Engine
