Weird AC issue
Old Jul 6, 2024 | 11:32 AM
HowlinC5's Avatar
HowlinC5
Default Weird AC issue
So I have searched and searched and can't see where anyone had this issue. Car has the electronic dual mode control. AC on the drivers side gets warm while driving but works fine when stopped. Tried reseting the system by pulling the fuses and that didn't work. Had the typical codes after doing that and cleared those. Is the blend door itself broken or is the actuator bad or could the whole module be bad? Car is 2004 with 160k on it.
Old Jul 6, 2024 | 11:45 AM
yellow2007's Avatar
yellow2007
The actuators are electrically controlled and vacuum operated. Try different positions, def,floor,dash to see if the air flow changes.
Old Jul 6, 2024 | 01:44 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
You should start by seeing if you have any HVAC trouble codes before diagnosing this…temp control are the actuators and air distribution is vacuum.
Old Jul 6, 2024 | 01:51 PM
mmartinez's Avatar
mmartinez
Check your Freon, many a corvette owner has had this problem and it was simply that the ac system was low.
Old Jul 6, 2024 | 08:10 PM
Bicklebok's Avatar
Bicklebok
I had the exact same problem and symptoms. It was low on freon.
To Weird AC issue
