quest for 12's
Old Feb 2, 2003 | 01:25 AM
MC TORCH RED's Avatar
MC TORCH RED
Default quest for 12's
with the mods that are posted what can i do to reach the 12'S i have pt2800,and 3.15's waiting on the garage floor for install in march, but can't wait that long. maybe tuning, or headers,etc. please help.... :chevy
Old Feb 2, 2003 | 01:37 AM
66ImpalaLT1's Avatar
66ImpalaLT1
Default Re: quest for 12's (MC TORCH RED)
best of 13.002 :lol: i think all you need is to keep trying!
Eric
Old Feb 2, 2003 | 01:47 AM
MC TORCH RED
Default Re: quest for 12's (66ImpalaLT1)
E i have been to 3 racetracks saME OLD S/// 2.03 60 foot, 13.002, 13.011,13.013 13. 13 ??????????????????????new run flats on rear no spinning. :confused:
Old Feb 2, 2003 | 01:58 AM
CCrane65's Avatar
CCrane65
Buy a set of drag radials and lower the air pressure to 15 pounds. I have hit 12.91 twice, once in a 00 coupe and again in an 02 vert. You can see my mods in my sig. Nothing exotic. Just work on your wheelspin and shift points. I have found that I go faster when I don't wait too long to shift. Peak horse power is not redline. I have done this with an MN6 both times. I'm guessing you should be able to do much better with your A4 (no clutch, no missed gears, etc.)
cc
cc
Old Feb 2, 2003 | 02:05 AM
MC TORCH RED
Default Re: quest for 12's (CCrane00)
C C looks like we have the same mph but u have faster e.t., i have no wheel spin most off the time track is well prep,each time i go 13.002 or 13.011 0 tire spin, don't think drag radials are needed yet . what else could it be... maybe poor drive n. i shift at 5900. maybe i should just let it shift itself. :chevy
[Modified by MC TORCH RED, 1:07 AM 2/2/2003]
Old Feb 2, 2003 | 09:15 AM
vstella's Avatar
vstella
Buy a set of drag radials and lower the air pressure to 15 pounds.....
cc
:iagree: I found my 60' times dropped significantly..a good 60' will improve your E.T. Dragging with street tires are futile... :rolleyes:
Old Feb 2, 2003 | 10:06 AM
davidmax's Avatar
davidmax
Default Re: quest for 12's (vstella)
A small 75-100 hp shot of juice will wake her up.Also I would before installing the 3:15's see if you can swap up to a 3:42 I thinl the increase in Tqe. Multiplication would make you very happy.Good Luck Dave S. Xtreme
Old Feb 2, 2003 | 11:01 AM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
Default Re: quest for 12's (davidmax)
get your 60' times down and you'll hit 12s easily ;) :cheers:
Old Feb 2, 2003 | 11:17 AM
MC TORCH RED
Default Re: quest for 12's (Mean Green 2000)
how do i get 60 ft. times down..not spinning at all. :chevy
Old Feb 2, 2003 | 12:31 PM
ICULUKN-C5's Avatar
ICULUKN-C5
get nitrous...
Old Feb 2, 2003 | 12:33 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI IV Bracket Champ
I just saw you had 2.73 gears....change them out and a converter or a set of DRs as mentioned but with any of the above options, get a line-loc so you heat those tires up nice and good....I cut 1.9x on Nitto Streets all day long :D
Old Feb 2, 2003 | 12:53 PM
ICULUKN-C5's Avatar
ICULUKN-C5
GET ET STREETS & NITROUS AND RUN 11'S
Old Feb 2, 2003 | 06:40 PM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
You are not spinning at all but you are not pushing it at all either. A 2.03 60' with no spin says you are simply not leaving hard enough.
You should be able to spin the tires like crazy on street tires with a 2800 stall converter.
With a 2800 stall converter and 3.42s you should be 60'ing high 1.7 low 1.8 but street tires may not be able to do that for you.
Old Feb 2, 2003 | 07:16 PM
MC TORCH RED
Default Re: quest for 12's (REDGAR)
RED GAR LOOK AT POST AGAIN , I HAVE 2800,AND 3.15'S ON THE FLOOR FOR INSTALL IN MARCH ...NOT IN CAR YET. PLEASE REPLY AGAIN THANKS FOR ANY INFO..
Old Feb 2, 2003 | 07:52 PM
REDGAR's Avatar
REDGAR
CI VI Drag Champ!
Opps my bad.
The tuning should help you get there especially with change in shift points a little higher.
Headers will help also but you probably also want to do the tuning then too.
Old Feb 2, 2003 | 08:00 PM
MC TORCH RED
WHAT KIND OF HEADERS , I AM NOT PLANNING ON CAM AND HEADS,LS1 EDIT OR ANOTHER TUNE, WHAT DO YOU THINK. HEADERS AND EDIT WILL I GET MAYBE .2 OR .3 ...THANKS FOR INFO.
Old Feb 2, 2003 | 08:03 PM
MC TORCH RED
when you said change in shift points what do you mean , will the car shift before 5900 or after. don't want to blow anything :steering:
To quest for 12's
Old Feb 2, 2003 | 09:16 PM
Lynn2008's Avatar
Lynn2008
[QUOTE]C C looks like we have the same mph but u have faster e.t., i have no wheel spin most off the time track is well prep,each time i go 13.002 or 13.011 0 tire spin, don't think drag radials are needed yet . what else could it be... maybe poor drive n. i shift at 5900. maybe i should just let it shift itself. :chevy
I thought most people let the a4 do the work. Do you start in 3rd?
Old Feb 2, 2003 | 09:34 PM
MC TORCH RED
Default Re: quest for 12's (ericg320)
now i do , i was trying to shift myself but kept hitting re limiter now i just put it in drive and go, i cut .2 doing it that way.
Old Feb 2, 2003 | 10:15 PM
Lynn2008's Avatar
Lynn2008
Doesn't that put you in the 12's?
