Changing brake fluid after fixing ECBM
Allow yourself plenty of time
The job is much easier with a wife helping.
Use a plastic tool to pop the main wiring connector loose.
Don't damage the mounting o ring as they are no longer available.
Search threads here for good write ups and pictures.
150,000-Mile Service
In addition to the basic services, at the 150,000-mile mark, the service technicians will change the rear axle fluid in all-wheel-drive models, drain and fill the engine’s cooling system, visually inspect the accessory drive belts, replace the hood and/or body lift support gas struts, and replace the windshield wipers.
Mileage Recommended Maintenance 7,500 Change Oil and Filter, Lubricate Doors 15,000 Change Oil and Filter, Cabin Replace Air Filter, Lubricate Doors 22,500 Change Oil and Filter, Lubricate Doors 25,000 Replace Air Filter, Cabin Replace Air Filter 30,000 Replace Air Filter, Lubricate Doors, Change Oil and Filter, Cabin Replace Air Filter 37,500 Change Oil and Filter, Lubricate Doors 45,000 Change Oil and Filter, Cabin Replace Air Filter, Lubricate Doors 50,000 Replace Air Filter, Cabin Replace Air Filter 52,500 Change Oil and Filter, Lubricate Doors 60,000 Replace Air Filter, Lubricate Doors, Change Oil and Filter, Cabin Replace Air Filter 67,500 Change Oil and Filter, Lubricate Doors 75,000 Replace Air Filter, Lubricate Doors, Change Oil and Filter, Cabin Replace Air Filter 82,500 Change Oil and Filter, Lubricate Doors 90,000 Replace Air Filter, Lubricate Doors, Change Oil and Filter, Cabin Replace Air Filter 97,500 Change Oil and Filter, Lubricate Doors 100,000 Replace Air Filter, Spark Plugs Replacement, Transmission Fluid Service, Cabin Replace Air Filter 105,000 Change Oil and Filter, Cabin Replace Air Filter, Lubricate Doors 112,500 Change Oil and Filter, Lubricate Doors 120,000 Replace Air Filter, Lubricate Doors, Change Oil and Filter, Cabin Replace Air Filter 125,000 Replace Air Filter, Cabin Replace Air Filter 127,500 Change Oil and Filter, Lubricate Doors 135,000 Change Oil and Filter, Cabin Replace Air Filter, Lubricate Doors 142,500 Change Oil and Filter, Lubricate Doors 150,000 Replace Air Filter, Cooling System Flush, Lubricate Doors, Change Oil and Filter, Cabin Replace Air Filter
This is for c5
, is there anything else that might be the case, ive heard the relay can go bad but i havent had any codes from the ebcm. Maybe my solders were bad any advice?
