Need Advice on Brake Light Switch Malfunction
Old Jul 17, 2024 | 08:46 PM
Constellar Nova's Avatar
Constellar Nova
3rd Gear
Default Need Advice on Brake Light Switch Malfunction
Hello all, joined the forum today in hopes of getting some help from those who've been around the block with 'Vettes.
Couple days ago I pulled a C1291 code from my '98 C5 I just bought 2 weeks ago. Did some looking here the past few days to run diag and other things I could do myself; check fuses etc. I and my more mechanically inclined co-workers at a shop I work at are pretty sure its the brake light switch itself, which has so far proven impossible to source in northern NJ/tristate area.
I've reached out to the dealer I bought the car from and we're trying to work that out, my shop and several parts shops in the area are on the lookout for a switch. So really, I'm here to spread my net out as wide as I can. The nearest reputable Corvette specialist is probably a half hour to an hour away, and there's no guarantee they have one. Does anyone have any ideas? And a follow-up question I didn't really see an answer to is; Are brake light switches from other 'Vettes compatible with the C5? I know there's a fair bit of parts sharing and compatibility with corvettes of different generations, but just how far does it go?
Thanks, Nova
Old Jul 18, 2024 | 11:23 AM
mmartinez's Avatar
mmartinez
I know it's a last resort, but have you considered buying a used one? Call Mark at Vettenuts a corvette salvage yard.
Old Jul 18, 2024 | 12:44 PM
mmartinez's Avatar
mmartinez
I searched the internet and found several sources to buy that switch, might have to wait several days to get it delivered.
Old Jul 18, 2024 | 02:09 PM
lucky131969's Avatar
lucky131969
Originally Posted by Constellar Nova
I and my more mechanically inclined co-workers at a shop I work at are pretty sure its the brake light switch itself.......
Mechanically inclined doesn't always help when you need electrical expertise. This is a pretty simple troubleshooting procedure in your service manual in Brakes>Antilock Brake System>Diagnostic Information and Procedures>DTC C1291.......
No reason why you should not be absolutely certain if you have a bad switch or not. Just need a DMM.
Is your EBTCM front or rear mounted?
Old Jul 18, 2024 | 06:52 PM
Constellar Nova
3rd Gear
I'll keep Vettenuts in mind. The car's out of my hands at the moment but if I end up needing that switch then yeah, online's my best bet.
Old Jul 18, 2024 | 07:03 PM
Constellar Nova
3rd Gear
My C5 is a May 29th '98 model with active handling, I don't have the car at the moment to confirm but EBTCM should be in the front.
Old Jul 18, 2024 | 10:43 PM
lucky131969
Ummm..ok. If it's in the front, the troubleshooting will be easier. Good luck.
To Need Advice on Brake Light Switch Malfunction
