LS1 Heads
Old Jul 19, 2024 | 01:32 PM
Bryan M's Avatar
Bryan M
Default LS1 Heads
I was wondering if any one has done any head work or aftermarket head replacement for an LS1 motor. I have a 1997 Corvette and I was just wondering if replacing the heads with aftermarket. If so, what brand or using factory heads and having some work done to them? Any thoughts and thank you
Old Jul 19, 2024 | 10:47 PM
Navy Blue 210's Avatar
Navy Blue 210
What are your goals for the car?
What is your budget?
Do you need to pass smog?
Old Jul 20, 2024 | 12:35 PM
Prop Joe's Avatar
Prop Joe
Slippery slope... Make sure you have a tuner lined up.
My story:
https://www.corvetteforum.com/forums...-coupe-m6.html
You can have your heads CNC ported, or find a "Core" set. I have a set of 1998 heads with about 50K miles on them, PM if interested:
https://www.texas-speed.com/p-1172-p...-castings.aspx
Or you can just buy a brand new set of heads/Springs/valves. These look to finally be in stock now. I probably would have just ordered these, but were not available or even offered when I put heads/cam/headers on my car.
https://www.texas-speed.com/p-18424-...retainers.aspx
I've had good luck with the "Stage IV" Texas Speed "low Lift" Cam kit I ordered. 431 rwhp/400 tq when I had it tuned.
https://www.texas-speed.com/p-1158-t...l-cam-kit.aspx
Many choices for head/cam swaps. Do your research as to what works.
Its a lot of work, but very doable if you are mechanically inclined.
http://www.ls1howto.com/index.php?article=1
To LS1 Heads
