Goes into gear but stalls
My issue which has happened 2 times so far is when taking off in a parking lot I put it in first, it clicks in but when I launch it acts as if the brakes are locked up. If I let the clutch out it stalls, if I put it in 2nd, 3rd, or N and back to 1st I get not change.
My get-it-moving fix is to shift through the gears 1-6 then reverse then put it in first and it's fine.
A few notes about the car that may be relevant: The seller claimed to put a new transmission In, upon visual inspection it's obviously not a new trans as the sticker is mildly faded but the trans is pretty clean, 's likely a rebuilt one if new at all. 2nd note, if you click to 1st wrong it hits a false neutral and with the clutch fully depressed if you try to fully push it into 1st it grinds. To get around this I take it out and put it back in.
It grinds 1st to Reverse but not 6 to Reverse.
lastly, I notice the clutch grabs low and harshly.
I've seen some torque tube issues that sound like they could match my symptoms as well as some clutch/throw-out bearing issues. Has anyone dealt with this issue or have any diag tips?
