Harmonic balancer?
Old Jul 23, 2024 | 02:28 PM
colderbythelake's Avatar
colderbythelake
Default Harmonic balancer?
At how many miles should you start thinking about replaciing the harmonic balancer? Thanks!
Popular Reply
Jul 23, 2024, 03:07 PM
vette4fl's Avatar
vette4fl
It’s held together with rubber, essentially, so at some point it will weaken. That event timeline seems to vary widely, based on accounts from the forum.
You can paint a white line diagonally from the center to the outer ring to help detect slippage. The other thing is wobble, as mentioned above.
I used the “possibility” of failure as an excuse to go in and swap the cam and heads 😀, and replace the balancer “while I was in there”. And trust me, if I can do it anyone can.
Old Jul 23, 2024 | 02:33 PM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
When it wobbles usually.
Old Jul 23, 2024 | 02:43 PM
oktx's Avatar
oktx
Miles really have nothing to do with it. It's age.
Old Jul 23, 2024 | 03:07 PM
vette4fl's Avatar
vette4fl
Old Jul 23, 2024 | 03:25 PM
captain vette's Avatar
captain vette
I have just changed mine 3 weeks ago 2003
With 60k there was a light wobble and the serpentine have started screaming for awhile put a Summit Racing in and now it’s perfect
Old Jul 23, 2024 | 05:50 PM
Vader_C5's Avatar
Vader_C5
2023 C5 of the Year Winner - Unmodified
St. Jude Donor '25
I replaced the one in my '99 just before 100k miles. As others have noted it's an aging rubber part, though some are more resilient than others.
One way I recently discovered to check the "wobble" is to take a slow-mo video of the balancer, this Is a good way to determine the amount of wobble you might have.
Old Jul 24, 2024 | 09:14 AM
jjc508520's Avatar
jjc508520
I have 85k on mine with no wobble - I make sure to drive it year-round. When I took it to ECS for clutch and torque tube they found I was leaking oil at the front (that was a surprise - I had expected rear) - and the reason was that the front seal had cut a groove into the balancer resulting in the leak! Damper and seal replaced…
Old Jul 24, 2024 | 11:48 AM
hyperv6's Avatar
hyperv6
The factors I see often at play is this. Miles, Age, where you live climate wise and how it is driven. The cars that are driven hard and raced can lose a balancer much sooner.
Automatic cars and cars with lower miles and not driven hard can last longer. The real key is just eyeball it and watch for any increase in wobble. They fact is they all wobble a slight bit bit if it increases and or you see it hitting the steering rack. It is time.
If and when just do the Summit Balancer one. It is the highest quality for a very good price. Also consider changing the front seal and cover and Summit offers that too. Change belts if old and check the water pump while you are there and you may want to do that while it is appart.
Old Jul 24, 2024 | 12:07 PM
vette4fl's Avatar
vette4fl
You may be unfairly overlooking the Tractor Supply Hybrid Spinster 9000-X. It’s built with genuine metal and hydro plastic components. Includes an adjustable crank hub to fit most domestic and Central Asia models.
Old Jul 24, 2024 | 12:08 PM
Moving this to C5 Tech.
Old Jul 24, 2024 | 12:20 PM
colderbythelake
Thanks Good idea!
Old Jul 28, 2024 | 01:43 AM
James Dean's Avatar
James Dean
I've replaced a few over the years. The Summit and OE style seem to be the ones that last the least amount of time and the rubber fails. The ATI seems really good but one failed and hit the steering rack on a friend's car (6 years old track car) and it was a PAIN to remove.
Doing my own, I did a Fluidampr since it has no rubber bond to fail and using the ARP bolt it's got no play either. I retorqued it after a week to be safe but it was fine. About 5k miles since (5 months) and still golden.
Old Jul 28, 2024 | 01:50 AM
Arc_Light's Avatar
Arc_Light
Just keep an eye on it. You'll know if it ever starts to wobble. Many LS2 owners never have a problem.
Old Jul 30, 2024 | 08:42 PM
Meyersb17's Avatar
Meyersb17
That’s crazy! Thanks for sharing.
Old Jul 30, 2024 | 10:17 PM
Markolc1981's Avatar
Markolc1981
I just replaced mine a couple months ago, it was wobbling a little bit, but not bad for 177k. But the oil leak, yuck. When I removed my balancer I had found the same groove worn into mine.
Old Jul 31, 2024 | 07:35 AM
hyperv6's Avatar
hyperv6
Most balancers wobble. It should just be a small amount. Don't over react on a small bit.
As for failure of the Summit Balancer or most other SFI rated balancers it is next to nothing unless they were damaged in some way. They are built to high standards and the failure rates are extremely low.
If you use one you likely have fixed it for the life of the car.
Old Apr 14, 2025 | 09:27 AM
chevyvette98!'s Avatar
chevyvette98!
KUBS, what front spoiler do you have?
To Harmonic balancer?
