Chasing down an engine noise. Please help!
Old Jul 27, 2024 | 10:56 PM
Red01c5a4's Avatar
Red01c5a4
4th Gear
Default Chasing down an engine noise. Please help!
You can hear it upon light revving until about 2500rpm then goes away. Can’t really hear it at idle. And doesn’t happen every rev, and it seems to go away upon a held rev. Literally only when first revving can you hear it. Maybe very early knocking or cam failure?
78k miles, stock with Corsa exhaust. I’ve only owned it a month, but oil looks good, no performance issues or engine lights.
The harmonic balancer is a bit wobbly and I have the summit racing replacement ordered, maybe that’s related? Since it happens only at a rev I can’t pinpoint where it’s coming from, but seems to be the driver side or around the intake manifold or front of the engine.
File Type: mov
Old Jul 28, 2024 | 02:07 PM
helga203's Avatar
helga203
Sounds like something is loose. I dont think thats the engine.
Old Jul 28, 2024 | 03:05 PM
Red01c5a4's Avatar
Red01c5a4
4th Gear
I think you’re into something. The HB is rattling the tensioner like crazy. While I dont think its the tensioner, the vibration may be shaking something else. Can hear it better here.
My summit HB comes in tomorrow so I guess we’ll know middle of the week! Fingers crossed.
File Type: mov
Old Jul 29, 2024 | 11:20 AM
CinciZ06's Avatar
CinciZ06
To me it sounds like a tensioner or idler pulley. They are relatively cheap for a quality gates or acdelco part, and are wear items. I would replace for sure irrespective of the noise given the age and mileage.
Old Jul 29, 2024 | 12:09 PM
helga203's Avatar
helga203
If you have a back up car, try takeing all the belts off and go from there.
Old Jul 29, 2024 | 12:15 PM
Red01c5a4's Avatar
Red01c5a4
4th Gear
Good idea, thankfully this is my weekend warrior so I’ll pop the belt off to check things up front. I did replace the idler pulley recently with a c6 one, but it does still shake from the HB being wobbly. I’m feeling better about it being accessory related. I’ve never heard an internal engine noise like this so can’t imagine what it’d be unless it’s really bad like a cam or something I’ve never heard before.
Old Sep 2, 2024 | 01:48 PM
George_L's Avatar
George_L
Thanks for the feedback. The car had been running about 10 minutes. The sound does not go away after the car has been driven and fully warm. I had the injector tick on my 2014 but this sounds higher pitched and louder to me. This is my first experience with the LT5 engine so it could be normal but my friend's ZR1 does not have this sound.
Old Sep 2, 2024 | 02:21 PM
helga203's Avatar
helga203
Any updates??
Old Sep 2, 2024 | 02:40 PM
Red01c5a4's Avatar
Red01c5a4
4th Gear
Any updates??
Not yet, it hasn’t been cool enough to tackle it. I’m hoping next month I’ll finally get to it. I’m starting to think it’s the harmonic balancer banging against the timing cover as opposed to an internal noise, so that’s what I’m going to do first. I replaced the idler pulley and nothing changed but I noticed the HB wobbling quite a bit. I’ve driven it once or twice since then and it still drives fine, full power, no notable issues other than the awful noise. Fingers crossed!
Silver lining is I’m going to install and pin an upgraded HB for an eventual supercharger, so one step closer to that dream coming true.
Old Sep 2, 2024 | 03:18 PM
helga203's Avatar
helga203
Yup i think you got it.
To Chasing down an engine noise. Please help!
