Shifting issues
Old Jul 30, 2024 | 12:37 AM
Gstigen's Avatar
Gstigen
4th Gear
Default Shifting issues
Hello all,
I have a 99 coupe with a six speed manual transmission that has recently started to become difficult to shift into reverse and, randomly pops out of second gear. Feels like maybe some type of linkage issue?? Can anyone recommend a good Corvette mechanic in the Minneapolis MN area that could diagnose the exact problem and provide a repair solution?
Thanks for any suggestions our advice
Old Jul 30, 2024 | 07:57 PM
Vader_C5's Avatar
Vader_C5
2023 C5 of the Year Winner - Unmodified
St. Jude Donor '25
Stock shifter?
I would consider the anti-venom mod and new trans fluid.
Old Jul 31, 2024 | 12:16 AM
Gstigen's Avatar
Gstigen
4th Gear
Originally Posted by Vader_C5
Stock shifter?
Thanks Vader for the advice, it is a stock shifter currently
Old Jul 31, 2024 | 10:40 AM
jpb1978's Avatar
jpb1978
Search the internet for "t56 pops out of reverse": You will see lots of info, basically you will need a rebuild.
Old Jul 31, 2024 | 01:00 PM
Gstigen's Avatar
Gstigen
4th Gear
Thanks for the info, it doesn't ever pop out of reverse only in second gear. I have to jiggle the shifter around to get it into reverse then once it is in it stays in until I shift to a forward gear.
Old Jul 31, 2024 | 07:14 PM
jpb1978's Avatar
jpb1978
In that case, try adjusting the shifter with the alignment pin.
Old Jul 31, 2024 | 11:06 PM
Gstigen's Avatar
Gstigen
4th Gear
Thanks allot for the help
Old Aug 1, 2024 | 01:11 PM
TMODcustoms's Avatar
0TMODcustoms
Former Vendor
This is typically for these cars, I have a few options to solve the problem. Getting increasingly harder then impossible to get into reverse is due to the bolt on the linkage being loose. The box under the shifter is also worn out and sloppy, for sure which adds to the problem and the vague sloppy feel of the shifter. To solve this problem you can remove that bolt, clean the threads off with brake cleaner and reinstall it with RED Loctite. If you want your shifter to feel a whole lot better you can send me your box to be upgraded, if you don't want to do that I recommend at the very least replacing the shifter bushing on the bottom of your shifter with the improved version I make, it helps a lot for what it is.
If you have any questions shoot me an email, I'm happy to answer anything I can.
Tom
Info@tmodcustoms.com
To Shifting issues
