Balancer install
Old Aug 11, 2024 | 09:55 PM
CamHM's Avatar
CamHM
Default Balancer install
Hey all, I'm in the middle of a balancer install. Got the old one off, started putting the new one (PBU1117SS10) on, which leads me to a couple of questions....
1. I heated the balancer up in the oven to around 170. It started ok but now I have to crank on it to keep moving it towards the engine. Is that normal?
2. In my haste after the balancer came out of the oven, I forgot to put some RTV in the keyway. Is it absolutely necessary to fill that keyway? If so, do I need to pull the balancer to fill it or can I use a little plastic syringe to fill it? If I do need to pull it are the threads whatever typical puller kits use?
Thanks!
Old Aug 11, 2024 | 09:58 PM
Mr. Black's Avatar
Mr. Black
No Hostility Be Happy
Heat it to 250 next time. It won't hurt anything. It cracks me up when guys say it will melt the seal.
Yes, it is always going to drag all the way on the snout unless you seriously overheat it.
RTV just back fill it with your finger as much as you can and then put a film behind the bolt head or washer. It will be totally fine.
I would not pull it back off.
Old Aug 11, 2024 | 10:05 PM
CamHM's Avatar
CamHM
Thanks for the super fast reply! I really appreciate it. It's like 3/4 of the way on. I was too excited to get the new one on so I rushed lol. So much for it going perfectly. Gonna take tomorrow off to leisurely work on it and get it running.
Old Aug 11, 2024 | 10:11 PM
Mr. Black's Avatar
Mr. Black
What are you using for a bolt? OEM? or ARP?
Either way take the old bolt and seat the balancer with it. As long as you are past half way it will seat when pre torquing it.
I've had many where I swore it was down all the way seated when jamming it on hot and then when we went to do the initial torque the balancer would move some more.
Old Aug 11, 2024 | 10:25 PM
CamHM's Avatar
CamHM
Yep, picked up an ARP bolt. I'm using some Amazon special install tool. It's ugly but I put a little oil on it to protect the threads from galling and it's worked ok so far. I heard using the old bolt to squeeze the balancer back on was a no-no but I didn't really understand why.
Old Aug 11, 2024 | 10:51 PM
Mr. Black's Avatar
Mr. Black
You don't want to use an old bolt to install a balancer from scratch, but you do want to use an old bolt to pre torque or seat the balancer in place after it's been pulled on with a good install tool. It isn't 100% necessary but is pretty common practice in the LS world.
Old Aug 11, 2024 | 11:16 PM
CamHM's Avatar
CamHM
Ah, ok. Makes sense. The threads on mine looked pretty good so I will definitely pre torque it with the old bolt. What are you thoughts on pinning? I plan on keeping the car NA but it will see some track use. I have a pin kit, but the parallel/front type. Can I pin it through the keyway on my balancer, thus negating the need for RTV? Or will the bit catch and break on the sharp machined corner?
Old Aug 12, 2024 | 09:08 AM
lucky131969's Avatar
lucky131969
Thanks!
..yes....but complete the install with a balancer install tool............not the bolt.
Old Aug 12, 2024 | 12:56 PM
CamHM's Avatar
CamHM
Does this depth look ok to everyone? Was gonna do the pin kit next.
Old Aug 12, 2024 | 01:41 PM
CamHM's Avatar
CamHM
I actually measured it and got .152" all the way around, which I believe is in spec. I'm about to pin it with the summit kit. Seems like the pins are kind of long? Planning to split the difference between the snout face and pulley face.
Old Aug 12, 2024 | 08:49 PM
Mr. Black's Avatar
Mr. Black
I just went and reviewed an old video of mine installing this very balance in my car. I would say you got it seated.
Crappy video for reference
I also have a crappy video on pinning if you want to compare pin lengths.
Old Aug 12, 2024 | 10:50 PM
CamHM's Avatar
CamHM
Thanks man! I really appreciate it. Got it all buttoned up and just took it for a test drive. Everything works great! Crossing my fingers that there's no puddles tomorrow morning. I was told by Dayco to use the stock belts, which is true for A/C but absolutely NOT true for the serp belt. I used a 79 7/16" Gates belt that is quiet as can be. I'll edit this post with the part number.
To Balancer install
