Hurts installed
Old Feb 3, 2003 | 02:09 PM
skidmarc's Avatar
skidmarc
Default Hurts installed
Ok I got the Hurst in..easy to install but upon acceleration the **** rattles.....tried wrapping elec tape around threads and putting **** on tight....tried felt tip at top of shifter.......nothing works.....whats up with this rattle??????????? I put the "demon key" back in tight.....I wont live with this rattle...but like the shorter throws!!!!!!!!!!!! It rattles with/without shift cap on...so its the ****!
Old Feb 3, 2003 | 02:22 PM
XportC5's Avatar
XportC5
Default Re: Hurts installed (skidmarc)
Try driving it without the ****, maybe you can eliminate the **** as the culpret, might be something else....
Old Feb 3, 2003 | 02:30 PM
skidmarc's Avatar
skidmarc
Default Re: Hurts installed (XportC5)
did that already....definitley the ****!
Old Feb 3, 2003 | 02:54 PM
StickTail's Avatar
StickTail
Time for a new ****. :smash:
Don't worry you will like it. :thumbs:
I went with the flameball and love it.
What do you think of the shifter?
Old Feb 3, 2003 | 03:06 PM
skidmarc's Avatar
skidmarc
Default Re: Hurts installed (fdupny)
the shifter is a bit notchy but I guess it has to break in!
I cant find a new **** I like......I seem to remember past posts on this problem!
Old Feb 3, 2003 | 04:18 PM
Loaded45's Avatar
Loaded45
I got the exact same noise after I installed my B&M Ripper. It drove me nuts! Then I saw this fix on the Forum a while back and it and it totally eliminated the noise. I still even use the stock shift ****.
Go down to your local tire shop and get a handful of tape-on wheel weights.
With a couple of pliers, bend the weights so they are crescent shaped.
Now place them on the shifter shaft.
Use as many weights as you can get on it.
Secure them with some small zip ties.
[Modified by Loaded45, 3:19 PM 2/3/2003]
Old Feb 3, 2003 | 04:38 PM
9tee9c5's Avatar
9tee9c5
Default Re: Hurts installed (Loaded45)
I also had this issue with the Ripper. The wheel weights are probably the best way to go. I used rubber hoses. I took the shifter to a friend's auto parts store and played with various hoses. The hoses dampened much of the noise, but it was still there. I put on a billet **** and believe it or not, the noise is completely gone. I used the **** from Corvette Concepts - it has the corvette flags on the shifter. It gets cold/hot, but only in extreme conditions. I keep a flimsy coolie holder nearby to pout on top of the shifter until the temperature is good. Hope this helps.
Old Feb 3, 2003 | 04:44 PM
SideStep's Avatar
SideStep
I must be one of the lucky ones, because mine never rattled, vibrated, or anything! When you twisted the factory **** back on did you run it down until the it would turn no more? That is what I did, it just so happens that the **** was point in the correct direction when it bottomed out on the shaft...
..just an idea... :D
Old Feb 3, 2003 | 05:43 PM
skidmarc's Avatar
skidmarc
Default Re: Hurts installed (SideStep)
I played with it until the **** was all the way down and pointed foward.....
It seemed as though it was the ****...not the shaft...I wonder why the weights work.....???
Old Feb 3, 2003 | 07:55 PM
CCrane65's Avatar
CCrane65
Really weird thing here is I ended up with the factory **** back on because the billet polished aluminum Kirban **** and the black anodized crossed flags **** both allowed too much vibration through. The factory **** is much quieter on my car than the other two *****.
Go figure.
Old Feb 3, 2003 | 07:59 PM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
Default Re: Hurts installed (CCrane00)
Hey Marc, glad you like your new stick.. I hear its a bit shorter :D :D :D :p: :p:
Old Feb 3, 2003 | 08:38 PM
9tee9c5's Avatar
9tee9c5
Default Re: Hurts installed (CHRIS NJ C5)
The weights absorb some of the sound. I used the hoses to dampen - the stock shifter uses something to dampen.
This issue has been long discussed with as much as 50/50 split in who had noise and who did not.
One other item, sometimes I find myself pulling on the **** after a 1-2 shift and this seems to trigger some noise. Not really a rattle, more of a vibration. Good luck.
Old Feb 4, 2003 | 05:09 AM
vettenuts's Avatar
vettenuts
Default Re: Hurts installed (9tee9c5)
I used Teflon tape and wrapped the threads a number of times. The shift **** noise went away. However, then I got noise from the transmission tunnel and the shifter ended up back in the box. The notchiness didn't go away and I didn't think it was a good addition to the car overall. I may try it again this summer after the caravan though.
Old Feb 4, 2003 | 06:51 AM
JeffMc's Avatar
JeffMc
My experience with rattle and Hurst:
Stock **** = Ratter
MGW **** = No Rattle.
That's what I know and stickin' to it. :)
- JeffMc
Old Feb 4, 2003 | 07:28 AM
Patches's Avatar
Patches
Default Re: Hurts installed (JeffMc)
Stock **** = Ratter
:iagree:
To Hurts installed
