Need help with new wheels
Old Aug 22, 2024 | 03:31 AM
Rocky_LS6's Avatar
Rocky_LS6
Default Need help with new wheels
What’s up guys so I have a 03 C5Zo6 on the factory wheels as of right now and I placed a order for the
fordgestar F14 (18x9.5 up front) then (19x12)
WITH THE FACTORY OFFSET
in the back But here’s the issue I’m very worried as if the wheel will stick out from the fender a lot Even tho I got as close as I could to the factory off set let me know if you guys know thank you.
Rocky
870-627-0044
Old Aug 22, 2024 | 07:25 AM
Beast's Avatar
Beast
Yup, looks like you’re going to pick up some wide body fenders too. It will look great once completed.
Old Aug 22, 2024 | 07:26 AM
Rocky_LS6's Avatar
Rocky_LS6
Not wanting to go wide body so do you think mabey a 19x11 will be better?
Old Aug 22, 2024 | 09:27 AM
lucky131969's Avatar
lucky131969
Rocky
870-627-0044
Is there a weight savings advantage with the Forgestar 14? I mean appearance-wise, it is the ZO6 rim with 2 more spokes.
Old Aug 22, 2024 | 10:14 AM
MetalMan2's Avatar
MetalMan2
Let's do some quick math... if the rear wheel offset is the same, and the wheel is 1.5" wider than a C5 Z06 rear wheel, then the wheel will "stick out" half of that extra width which is 3/4" (19mm). Just try to envision that. IMO it's too much.
Old Aug 22, 2024 | 11:44 PM
USAZR1's Avatar
USAZR1
Yes but can you get the wheels you want, in a 19x11 sizing? If so, a +59 offset would fit fine.
19x12 with +59 offset is a C6 Z06/Grand Sport fitment.
Old Aug 23, 2024 | 12:09 AM
Rocky_LS6's Avatar
Rocky_LS6
Under stood I Ordered the 56mm+ in the rear should be exactly how I want it
Old Aug 23, 2024 | 08:39 AM
Beast's Avatar
Beast
I use a 19x10.5 +54 offset in the rear, with a 305 30 tire. Rear tire pokes about 1/8 inch. You can barely tell. I can live with that. A 19x12 with roughly the same offset as me, will poke like 3/4 inch on each side??? Make sure you don’t rub the inner fender??? And it will look like you have wheels and tires poking out the side 3/4 to 1inch. You can probably get the 19x11 to fit fine provided you get the right offset. And you should be able to use a 305 or 315 tire.
Good luck. Post pictures when completed.
Old Aug 23, 2024 | 02:27 PM
USAZR1's Avatar
USAZR1
+56 offset for what width?
Old Aug 24, 2024 | 05:55 AM
Rocky_LS6's Avatar
Rocky_LS6
Default Fordgestar f14
19x11
To Need help with new wheels
