C5 spin no start
Old Aug 22, 2024 | 10:58 AM
rvmeisen's Avatar
rvmeisen
Default C5 spin no start
Got an interesting issue. My 04 C5 will, about 1 out of 5 times, spin with no start or will fire but stumble and die immediately. Once it does this, I can spin it for as long as i want with no hint of starting. If I cycle the key a few times eventually it will start and run no issue.
It has the issue when it is cold or after it has been sitting for over an hour or so, never when just been running, It acts like no fuel.
Changed the ignition switch due to other issues. Thought maybe it would have an impact, no change.
Seems to me pump is good, so has to be something in between. I sure hope so, 04 is a bear to replace.
C5 has no fuel pump relay that I can find, just a fuse. Looked over wiring and grounds that i can get to. All are tight and clean.
Any ideas would be appreciated.
thanks in advance
Old Aug 22, 2024 | 11:16 AM
lucky131969's Avatar
lucky131969
thanks in advance
You need to test fuel pressure at the rail with the key to on to be sure.
Your owners manual explains exactly where the fuel pump relay is, as does the back of the underhood fuse box cover.
Old Aug 22, 2024 | 11:23 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
While the car is cranking look at your Tach and if it doesn’t move this may point to a bad crank sensor…with key on do you hear the pump run for 2 seconds and shut off ??
Old Aug 22, 2024 | 12:25 PM
rvmeisen's Avatar
rvmeisen
checked the relay, swapped for one of the other ones. When I googled the fuses got a different one back. Gotta find an owners manual, didn’t get one with the car.
When I hear it, it cranks.
tach doesn’t seem to move when it cranks, fires up on just about first rotation when it is good. Have to wait to see when it fails next
thank you guys for the quick replies.
Old Aug 22, 2024 | 12:36 PM
C5 Diag's Avatar
C5 Diag
If you turn the key on and hear the pump run for 2 seconds
it’s not the fuse…a crank no start is easy to diagnose…you just need to follow a diagnostic process…when you say “when I hear it, it cranks”…do you mean when you hear the fuel pump it “starts” ??…verbiage is important when describing this.
Old Aug 22, 2024 | 05:06 PM
rrwirsi's Avatar
rrwirsi
Do not know your electrical or mechanical skills, but the C5 is a 'Rubix Cube' challenge to find what the problem is if you are not proficient in both. Before throwing money and parts at the problem, it may be more efficient and economical to let experts sort out the problem and fix it. A good source to find experts is from your local Corvette Club. JMHO.
Old Aug 22, 2024 | 05:16 PM
rvmeisen's Avatar
rvmeisen
Sorry, you are right, verbiage does matter.
So far, I hear the fuel pump every time and every time it has started no issue. I didn’t think it was the fuse as that tests good but I think it could still be an intermittent issue with the relay. It has not failed -yet- so if/when it does I will be able to add what I heard just before.
thanks to you and everyone that has given ideas/knowledge. It really helps and I appreciate it.
Old Aug 22, 2024 | 05:18 PM
C5 Diag's Avatar
C5 Diag
Well when it cranks but doesn’t start look at the Tach…if you hook up a fuel pressure gauge while cranking and if it is the crank sensor you will see the fuel pressure drop while cranking.
Old Aug 22, 2024 | 06:19 PM
mmartinez's Avatar
mmartinez
C5 Diag did you mean to say that you shouldn't see the fuel pressure drop, because if it is the crank sensor no injector pulses will be generated by the PCM.
Old Aug 22, 2024 | 06:24 PM
C5 Diag's Avatar
C5 Diag
If no ignition pulse from crank sensor fuel pump will stop working…you will not have control side feed power to the fuel pump relay…if after 2 seconds PCM sees crank sensor signal fuel pump relay control side feed remains energized.
Old Aug 22, 2024 | 07:32 PM
mmartinez's Avatar
mmartinez
Ok, thanks for the explanation.
Old Aug 31, 2024 | 09:20 AM
rvmeisen's Avatar
rvmeisen
Everyone, thank you for the help.
it was the Fuel Pump Relay (#35 on the chart). I swapped it for another and it had no issues, replaced the original and it re-occurred. Think this one is solved.
I really appreciate the information and discussion, it made this an easy fix.
Thanks again
Ron
Old Aug 31, 2024 | 09:43 AM
mmartinez's Avatar
mmartinez
Always good to hear when a problem has been resolved.
To C5 spin no start
