Popping/Backfire
Old Aug 27, 2024 | 03:46 PM
BRAVO1's Avatar
BRAVO1
VETERAN
Default Popping/Backfire
Just recently this car has been popping or backfiring a lot.....usually slowing down and sometimes taking off from a light or turn...
Ant ideas ?? Seeing a tuner on Thursday to see if the tune has changed...
Old Aug 27, 2024 | 03:59 PM
lucky131969's Avatar
lucky131969
Yes. Will you be doing the investigation, getting under the car while it's running, etc?
Old Aug 27, 2024 | 08:54 PM
jdmvette's Avatar
jdmvette
Night Owl for life
love me the pops and burbles
Old Aug 27, 2024 | 09:25 PM
dom04abp's Avatar
dom04abp
Do you have an OBD scan tool? I would check your fuel trims at idle and and under acceleration. Lots of backfire is indicating excess unburnt fuel. If your fuel trims are positive 10 percent or more, something is happening to tell the car to add more fuel.
Old Aug 28, 2024 | 11:14 AM
BRAVO1's Avatar
BRAVO1
VETERAN
Will see the tuner tomorrow let's see what he says.......
Old Aug 28, 2024 | 11:26 AM
lucky131969
Old Aug 28, 2024 | 03:33 PM
redzg's Avatar
redzg
My '99 did similar shortly after a clutch change -- found that they had let the engine sag during the change, and the air bridge unions had slipped at two locations, allowing some leakage. Reset my air bridge junctions and it cleared up idle and deceleration.
Old Aug 29, 2024 | 06:08 PM
Mc556's Avatar
Mc556
Most likely you have a lose coupling after the MAF.
Old Aug 30, 2024 | 12:48 PM
Joshclifford84's Avatar
Joshclifford84
+1 to unmetered intake air. Also when the HVAC vacuum system leaks, made my car pop alot on decel.
Old Aug 30, 2024 | 12:54 PM
BRAVO1's Avatar
BRAVO1
VETERAN
Tuner looked at computer only thing out of sorts was a misfire on cylinder 5......I think that is what might be causing popping.
Old Aug 31, 2024 | 03:12 PM
dom04abp's Avatar
dom04abp
Not sure why you went to a tuner instead of a mechanic. Do you get any engine codes? Does the exhaust smell like fuel? The fuel trims and 02 sensors would show signs of the misfire on that side of the engine. You need to determine what's causing the misfire. I would do an engine leak down test to ensure the cylinder is sealed tight if the misfire is isolated to a specific cylinder. An air leak at a coupler or vacuum line would random misfire at low rpms.
Old Sep 1, 2024 | 10:55 AM
BRAVO1's Avatar
BRAVO1
VETERAN
Thanks for all the input.....Not sure at this point but will work at looking for your recommendations.....
Old Sep 3, 2024 | 01:18 PM
0DARK30's Avatar
0DARK30
I had a similar problem after installing long tube headers. It didn't happen right away, but a few months after I had the car tuned it developed a backfire and sputtered at WOT. I was mad and initially thought the tuner may have made a mistake. Then I started with the basics. Put the scanner on and drove it. A MISFIRE code on cylinder 5 appeared. So I thought maybe coil pack. I switched the pack with another cylinder and drove with the scanner. It still had the same problem. So I checked the plug wire. And after I pulled off the insulated wire sleeve I noticed a melted area on the msd boot. Deep enough to lose energy at higher rpms... this was my problem. I threw some silicone in there temporarily and larer picked up some accel wires with ceramic boots that won't melt on the headers. That cured my issue. Good luck.
Old Sep 3, 2024 | 01:40 PM
0DARK30's Avatar
0DARK30
Originally Posted by 0DARK30
I had a similar problem after installing long tube headers. It didn't happen right away, but a few months after I had the car tuned it developed a backfire and sputtered at WOT. I was mad and initially thought the tuner may have made a mistake. Then I started with the basics. Put the scanner on and drove it. A MISFIRE code on cylinder 2 appeared. So I thought maybe coil pack. I switched the pack with another cylinder and drove with the scanner. It still had the same problem. So I checked the plug wire. And after I pulled off the insulated wire sleeve I noticed a melted area on the msd boot. Deep enough to lose energy at higher rpms... this was my problem. I threw some silicone in there temporarily and larer picked up some accel wires with ceramic boots that won't melt on the headers. That cured my issue. Good luck.
Correction It was cylinder 2.
To Popping/Backfire
