I did just as you wrote, I returned to its original state.Only now I have again direction indicators associated with the STOP light, as it is in the original. I want the STOP signal separate from the direction indicators. I took the STOP signal from the middle STOP lamp.
Have you installed a conversion harness like the one below? :
Sorry, this page does not open in my location. I thought you meant the Hyperflash type harness. I did not install the conversation harness. After separating the brake lights from the turn signal lights (by cutting the famous white cable), I took the signal for the brake lights from the middle brake light. Only that after this modification I do not have hazard lights in the rear lights, the front is ok. After connecting the white cable (as it was origanally) I have hazard lights in the rear, but the brake signal is again connected to the turn signal lights.
Sorry, this page does not open in my location. I thought you meant the Hyperflash type harness. I did not install the conversation harness...............
Below is a picture of the conversion harness:
You can do a search for "Corvette C5 European Taillight Tail Lamp Wiring Harness" to find a link you can open.
Below is an older thread on converting to Euro Tail Lights that might help:
