C5 Headlight Problem
Old Sep 13, 2024 | 06:35 PM
GaryGarrity's Avatar
GaryGarrity
5th Gear
Default C5 Headlight Problem
When I turn on the,headlights only the driver side pops up and when I turn them off drivers side goes down but then a Loud grinding noise
HELP!
Old Sep 13, 2024 | 08:39 PM
mmartinez's Avatar
mmartinez
Headlight actuator has plastic gears that fail you will have to rebuild using brass gears.
Old Sep 13, 2024 | 10:51 PM
rrwirsi's Avatar
rrwirsi
Or, replace the headlight motor.
Old Sep 14, 2024 | 12:08 AM
jim993's Avatar
jim993
Check the connections to the passenger side headlight. No noise at all from it when you turn on headlights?
The driver side gear need to be replaced, best with a brass gear that will last.
I put kits from Rodney Dickman in which included brass gears about 14 years back. From: garing@aol.com <garing@aol.com>
Old Sep 14, 2024 | 10:15 AM
Number-6's Avatar
Number-6
7th Gear
The grinding noise from the headlight is indicative of a bad plastic gear inside the headlight motor. If you are reasonably handy you can rebuild the motor yourself. Easiest way is to purchase a repair kit that includes a new brass gear, bump stops, and everything you need. There are several on the market. I purchased one a few years ago from "carguy8t8" on eBay. Note: I believe there are two different types of headlight motors in a C5, depending on your year. One year (I think 2000) both styles were used, and you need to get the correct kit.
https://www.ebay.com/itm/153889426096
Old Sep 14, 2024 | 11:16 AM
Lowend's Avatar
Lowend
The bad news is you need to rebuild the headlight motor, the good news is it only takes about an hour to do .
This is the most complete kit I've found - but there are lots out there. Make sure you get the T-brackets when you do the rebuild, it makes the whole assembly much easier to deal with.
https://www.amazon.com/dp/B0C2GR8C83/ref=sspa_dk_detail_4?psc=1&pd_rd_i=B0C2G R8C83&pd_rd_w=g9i2T&content-id=amzn1.sym.8c2f9165-8e93-42a1-8313-73d3809141a2&pf_rd_p=8c2f9165-8e93-42a1-8313-73d3809141a2&pf_rd_r=728V2Q2ER09Q0PG3XH0 4&pd_rd_wg=AhUvz&pd_rd_r=eee11c61-06d3-4269-9113-4b7f154ae813&s=automotive&sp_csd=d2lkZ2V 0TmFtZT1zcF9kZXRhaWw
https://www.youtube.com/watch?v=uwg6g0LT7Ic
Old Sep 20, 2024 | 10:55 AM
BRKLYN's Avatar
BRKLYN
Replaced two nylon gears, last time I went with brass gear kit. Carful not all motor casings the same. DIY
To C5 Headlight Problem
