Headlights upgrade
Old Sep 13, 2024 | 09:04 PM
2blklt4's Avatar
2blklt4
Default Headlights upgrade
Hi there, as you know stock headlights are so dull and barely illuminate.
What would be the most affordable upgrade?
98 coupe
Old Sep 13, 2024 | 10:46 PM
rrwirsi's Avatar
rrwirsi
My cheapest and easy install 'upgrade' was replacing the headlights bulbs with Sylvania Silverstar Ultra (9005 &9006), installing Radioflyer Hi-4 Harness(allows low beam to be on with high beam) and installed Radioflyer LED fog light upgrade bulbs.
Old Sep 14, 2024 | 12:27 AM
2blklt4's Avatar
2blklt4
So for the high/low beam bulbs can the swap be done just for bulbs and not using a new harness? Do not care if they will not run simultaneously
Old Sep 14, 2024 | 02:36 AM
heffray's Avatar
heffray
You can trim the middle outside tab and remove the inside ribs on a 9005 (65W high beam) bulb so it fits in the low beam (9005 55W low beam) position: this is a minor improvement, but still not good by modern standards. I'd also use a long life 9005: they tend to target a much shorter lifetime due to infrequent use, and that would be annoying for using often. I used this solution for a while before moving to Knightdrivetv LED lights, which are quite good but also not very cheap.
Old Sep 14, 2024 | 09:47 AM
rrwirsi's Avatar
rrwirsi
Yes, that is correct.
Old Sep 15, 2024 | 11:35 PM
jdmvette's Avatar
jdmvette
Night Owl for life
Old Sep 17, 2024 | 02:11 PM
03tripleblack's Avatar
03tripleblack
2024 C5 of the Year Finalist - Unmodified
I recently installed a set of Fahren 9005/9006 LED bulbs and a set of Auxito 880 LED fog lamps from Amazon. All are considerably brighter than stock and cost me about $140 CAD.
The fogs work great. A couple of issues with the headlights:
1. If twilight sentinel is on the lead lights won't flip back down sometimes when on low beam. If you switch to high beams before shutting car off, they'll always go back down on their own.
2. The Fahren LEDs have a turnable base with set screw. I don't know if they came misaligned or twisted during initial install...(I let my teenage son start installing them and then noticed the LED chips weren't at 3 and 9 o'clock)
3. Beam spread....they light up the world (which is awesome), but I got flashed a few times on my x-country trip. Not sure if it's truly beam spread or just people not happy and need to complain about something/anything.
To be sure, I intend to replace the entire housings with ACA Bi-LEDs at some point but at $1000 CAD...they're a bit lower on my priority list since I rarely drive at night anyway. Hope this helps.
Old Sep 17, 2024 | 04:31 PM
lucky131969's Avatar
lucky131969
So dramatic. How did we drive at night before LEDs ?
Old Sep 18, 2024 | 07:17 PM
2blklt4's Avatar
2blklt4
Thanks!
That was very helpful. You are being appreciated by all of members reading this...
Old Sep 18, 2024 | 07:28 PM
lucky131969
Thanks!
It's an open forum, so replies will be mixed in nature.
For $5 per month, you can upgrade your Corvette Forum membership to be sarcasm free.
Old Sep 19, 2024 | 08:28 AM
Joe Scafide's Avatar
Joe Scafide
Default Headlights
I used h i d bulbs better than l e d
Old Sep 19, 2024 | 09:16 AM
acroy's Avatar
acroy
I did the Silverstar route and it's good 'nuff for city use; where there is lots of ambient light. I have a set of good-quality LEDs and a relay sitting on the shelf I will try next. The identical bulbs did a most excellent job in my family vehicle recently - excellent beam pattern, no scatter. I drive the Vette @ night so infrequently it's not worth the $700+ for the custom aftermarket setups.
Old Sep 19, 2024 | 05:00 PM
2blklt4's Avatar
2blklt4
Keep going, you are more and more helpful
Old Oct 22, 2024 | 03:28 PM
Beast's Avatar
Beast
I just installed sylvania silver star ultra, I’m getting a buzzing sound at my fuse box when I one click the lights up. Buzzing sound doesn’t go away, second click, lights turn on, buzzing sound goes away. Any ideas what it could be?
Old Oct 22, 2024 | 04:04 PM
Beast's Avatar
Beast
NM, some wires were touching by the drivers side headlight. Took headlight out, moved wires, reinstalled.
Old Oct 23, 2024 | 11:33 AM
Beast's Avatar
Beast
So, car still making a buzzing sound after you turn the headlights on one click. Sounds like it could be a fuse relay??? Sylvania silverstar ultras have to much power for the car??? I used part number 9006. Could it be my battery, I know it’s low, I’ll throw it on my battery charger when I get home.
Reinstall the old low beams??? See what happens? What you guys think?
Old Oct 23, 2024 | 11:51 AM
acroy's Avatar
acroy
no idea those are regular ol' incandescents. I have the same.
To Headlights upgrade
