Biggest AGM battery
Old Sep 14, 2024 | 11:53 AM
Caveboy's Avatar
Caveboy
Active Streak: 90 Days
Default Biggest AGM battery
What is the biggest battery you could cram into a 99 C5. I have after marketing stereo, amps and alarm.
Old Sep 14, 2024 | 11:56 AM
helga203's Avatar
helga203
U need stronger alternator. More amp output.
Old Sep 14, 2024 | 12:05 PM
Caveboy's Avatar
Caveboy
I heard the C5 alternators are very sensitive. They even recommend rebuild instead of replace because there are different versions of the alternator for the same year.
Old Sep 14, 2024 | 01:02 PM
helga203's Avatar
helga203
Rebuild wont help you. Keep the original. They come a long way and they are very compatible with the chafging system. Try mecham. Brett on here sells them he guarantees then you will have no problems.
Old Sep 14, 2024 | 01:55 PM
Caveboy's Avatar
Caveboy
https://www.saccitycorvette.com/Big-3.html
I wonder how this work with a bigger AGM battery
Old Sep 14, 2024 | 02:18 PM
helga203's Avatar
helga203
Go for it, let us now how it does??
Old Sep 14, 2024 | 05:31 PM
Caveboy's Avatar
Caveboy
But what is the largest battery I could use in my car?
Old Sep 14, 2024 | 06:11 PM
helga203's Avatar
helga203
I used 1000amp but it doesn't matter if the alt cant keep up with the draw. lights will still dim until the high volume is turned and accessories turned off.
If you mean physical size you have to go measure the battery and find one bigger
Old Sep 15, 2024 | 11:31 PM
jdmvette's Avatar
jdmvette
Night Owl for life
Amazon Amazon
Old Sep 17, 2024 | 11:00 AM
tabbruzz's Avatar
tabbruzz
From a battery perspective, I thought the yellow top optima was good for this scenario...Just a thought
Old Sep 18, 2024 | 12:14 AM
Lowend's Avatar
Lowend
Here ya go
https://docs.google.com/spreadsheets...it?usp=sharing
TLDR: The Antigravity Battery is the most expensive and best
Old Sep 22, 2024 | 03:54 PM
cstricklen's Avatar
cstricklen
4th Gear
Group 78 will fit nicely. Anything bigger would require some kind of modification.
To Biggest AGM battery
