C5 Transmission: 4L60e compatability
Old Sep 15, 2024 | 11:42 AM
kdonahoe's Avatar
kdonahoe
3rd Gear
Default C5 Transmission: 4L60e compatability
Good morning,
Wondering if all of the C5 Vettes with auto transmissions are the same? I have an '02 and I'm looking for a transmission. I may pop for a nice stage 2 or upgraded trans from a reputable builder or considering a "junk-yard" trans to get me by for a while (though not crazy about doing the job twice).
Do I need to narrow my search or will any 97-04 4L60e work?
Also, is there any conflict mating any C5 3.42 differential with any 4L60e transmission?
Advice/help appreciated!
Old Sep 16, 2024 | 08:00 PM
grinder11's Avatar
grinder11
IIRC, in 2001 or thereabouts, GM updated the 4L60E with the 4L65E. I know the 65E uses a 5 pinion planetary gear, where the 60E is a 4 pinion......
Old Sep 16, 2024 | 11:22 PM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
GM made changes to strengthen and improve the 4L60E in 2001 including the 5 pinion gear but I thought the 4L65E was only in the C6 starting in 2005.
Old Sep 17, 2024 | 05:20 AM
kdonahoe's Avatar
kdonahoe
3rd Gear
I think that is what I have heard elsewhere…that improvements where made in 2001.
Old Sep 17, 2024 | 10:38 AM
MSG C5's Avatar
MSG C5
Yep. The 4L60E received the 5-pinion gearsets and some other stronger internals in 2001 but it remained the 4L60E throughout the C5 generation. My 2004 convertible was built on 3/5/04 and has the M30 Auto Trans code on the build sheet which is the 4L60E. I read earlier the 4L65E was paired up to GM trucks and 6.0 Liter vehicles in 2001 and then was used for the C6 Corvette in 2005 for one year only before GM switched to the 6L80, 6-speed automatic transmission in 2006.
So in answer to the original question, any C5 4L60E should work, but if you find one from a 2001-2004, it has the 5 pinion gearsets and some other stronger internals. RPM and A&A both referenced the same thing when I added my SC and 3.42 rear gears earlier this year.
Old Sep 17, 2024 | 11:03 AM
kdonahoe's Avatar
kdonahoe
3rd Gear
Thank you for this. Basically confirming what I had heard. Hoping to swap to a 3.42 diff as well…but staying NA.
Thanks again!
To C5 Transmission: 4L60e compatability
