Front Input Shaft - Slight Wobble
Old Sep 19, 2024 | 11:27 AM
CluelessCorvetteDude's Avatar
Navigator
Default Front Input Shaft - Slight Wobble
I just rebuilt my TT and have replaced my front input shaft once already for this job.. Am i freaking out, or is this much wobble okay once its in the car? Link below for video of wobble. Just need to know what to do.. Thanks.
https://imgur.com/a/XpA81HS
Old Sep 23, 2024 | 07:02 AM
Moved to C5 Tech.
Old Sep 23, 2024 | 01:29 PM
helga203's Avatar
helga203
Originally Posted by CluelessCorvetteDude
I just rebuilt my TT and have replaced my front input shaft once already for this job.. Am i freaking out, or is this much wobble okay once its in the car? Link below for video of wobble. Just need to kniw what to do.. Thanks.
Thats ***'ed .007 to .010 is max, if that, your is around .125 run out.
0
Old Sep 23, 2024 | 01:54 PM
lucky131969's Avatar
lucky131969
0
Disagree.
There are only two runout inspections in the service manual:
1) for the propeller shaft
2) for the snubber
Given that the input shaft is only supported by one bearing, and connected to the coupler, you can't rely on this observation for anything. If you really wanted to evaluate the input shaft, it should have done it while disassembled.
Old Sep 23, 2024 | 09:09 PM
helga203's Avatar
helga203
Originally Posted by lucky131969
Disagree.
2) for the snubber
Yup ur right. i did mine when it was off. didn't even think of it still in the TT.. The numbers that i stated were pre RKT. Trans. That's when i was having issues with mine figuring out the max run out.
To Front Input Shaft - Slight Wobble
