1999 vert
Old Sep 19, 2024 | 05:27 PM
slicker358's Avatar
slicker358
Default 1999 vert
After 14 years with my 95 coupe, I bought a 99 vert 6 speed. Can anyone tell me why the 'security' light seems to stay on. Also, sometimes when I start it the engine starts right up, but dies when I attempt to move the car forward. After a few times stalling like that it will finally move normally. Thank you for any help
Old Sep 20, 2024 | 11:57 AM
Moved to C5 Tech for some recommendations.
Old Sep 20, 2024 | 12:01 PM
lucky131969's Avatar
lucky131969
Post your codes:
http://www.stengel.net/diccodes.htm
Old Sep 20, 2024 | 12:49 PM
mmartinez's Avatar
mmartinez
Most likely the contacts in the Ignition switch that press against the keys resistor pellet which are part of the VATS. Do you ever see the pull key wait ten seconds message? The stalling is the 2mph fuel cut off that GM programed to address the column lock problems with the C5.
Old Sep 21, 2024 | 12:52 PM
Steven Meillier's Avatar
Steven Meillier
7th Gear
Default 1999 vert
I also get message, (pull key wait 10 seconds) what is the fix? How do I prevent this from popping up?
Steven Meillier
Old Sep 21, 2024 | 06:31 PM
mmartinez's Avatar
mmartinez
Best fix is to buy the LMC5 column lock bypass, takes very little time to install and they have great customer service.
To 1999 vert
