Hello
Old Sep 25, 2024 | 04:59 PM
cabler's Avatar
cabler
Cruising
Default Hello
Hello Vette aficionados. New to the forum new Vette owner. Retired Navy didn't have the flexibility to lug around a Vette and a Harley....not that i'm somewhat stationary I pulled the plug and acquired a C5 / 97 with 12K on the meter. Absolutely only issue is full ac blows real cold on the passenger side and real hot on the drivers side. Thinking its an actuator and the moduler and the wiring harness check good. Thoughts Gang??
Old Sep 25, 2024 | 05:24 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
Welcome, and enjoy your new ride.
Thank you for your Service!
Old Sep 25, 2024 | 06:21 PM
Hardwork18's Avatar
Hardwork18
Thanks for your service and welcome to the forum. You might look under the C5 area in the forum for help. Enjoy your ride.
Old Sep 25, 2024 | 08:33 PM
kkupec02's Avatar
kkupec02
Welcome.
Old Sep 25, 2024 | 09:13 PM
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
Welcome, a trip over to C5 section is in your future
Old Sep 25, 2024 | 10:07 PM
Welcome to the forum and congrats on becoming a first time Vette owner. Also, thanks for your many years of service to our country (retired Navy here too).
I am going to move this thread over to the C5 Tech section where other C5 owners can provide you with some helpful information on the HVAC issue your car is having.
Old Sep 25, 2024 | 11:07 PM
lucky131969's Avatar
lucky131969
Given that this a new-to-you car, I would start by having the system evacuated, leak tested, and properly serviced. That establishes a solid baseline for all troubleshooting, and you will know that the system is solid......and yes, an improperly serviced system will cause the issue you have. Good luck
Old Sep 25, 2024 | 11:30 PM
Dads2kconvertible's Avatar
Dads2kconvertible
Do you have a scan tool? Service manual?
If you search the C5 tech area for "blend door" several threads come up with pertinent information.
Old Sep 26, 2024 | 08:19 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Sounds like you’re low on refrigerant !!…it’s due to the design of the evaporator on these dual climate control systems…once the passenger side cools down not much left for the driver if low…if your low you have a leak…get that fixed FIRST.
Old Sep 26, 2024 | 09:12 AM
cabler's Avatar
cabler
Cruising
Thanks all. New to how this forum works as well. The AC system was repaired, had a leak, fixed and recharged. Been researching and next steps are resetting the actuator as it seems the problem lies there....we'll see. The challenge is this is my Florida car so need to wait till I get back down. I think I need a Virginia Vette as well. Thanks again all.
Old Sep 26, 2024 | 09:13 AM
cabler's Avatar
cabler
Cruising
Thank you.
Old Sep 26, 2024 | 09:22 AM
lucky131969
Were the repairs done at a shop or a DIYer? C5's are a different animal when it comes to refrigerant, and close will not cut it. It also seems to defy conventional wisdom, that the evaporator would supply cold air to one side of the car and not the other....but alas.....that is exactly how a deficient system in a C5 behaves. I have seen guys tear apart the whole dash to replace an actuator, only to have the same problem.....which involved a improper refrigerant service. In the words of Forest Gump ".....that's all I have to say about that".
Old Sep 26, 2024 | 10:05 AM
Markolc1981's Avatar
Markolc1981
I had similar issue with my AC this Spring. Only one side blew cold, and the other warm. It was low on refrigerant, due to leaky compressor.
Old Sep 26, 2024 | 10:08 AM
BigBS's Avatar
BigBS
Welcome and thanks for your service!
To Hello
