Tire size and Traction control
Old Oct 2, 2024 | 08:15 AM
wetskier2000's Avatar
wetskier2000
Default Tire size and Traction control
I think running 17" front wheels on all 4 corners is making traction control come on at 40-50 MPH. If I configure the tire size with HP Tuners to all 17s, will Traction Control respect that and NOT think there is wheel spin?
Old Oct 3, 2024 | 12:11 AM
USAZR1's Avatar
USAZR1
What tire sizes are on the front and rear?
Old Oct 3, 2024 | 07:42 AM
wetskier2000
I have stock Fronts on all 4 corners: 245/45R17, Stock Rears were: 275/40R18. Front height 25.7", former rear height 26.7".
Old Oct 3, 2024 | 03:02 PM
Dads2kconvertible's Avatar
Dads2kconvertible
You specifically asked if you can tune out the issue with HP tuners and I don't have that answer.
For future readers considering changing tire sizes if you want to avoid traction control issues your goal is maintain the same difference in tire circumference that the car had with stock sizes.
That means when you have a smaller wheel you need a taller sidewall if you keep the same tread width. There are tire size calculators online to assist in figuring this out.
Old Oct 3, 2024 | 04:36 PM
USAZR1's Avatar
USAZR1
While some people's goal is maintain the same difference in tire circumference that the car had with stock sizes, the AH/TC on these cars isn't that sensitive that doing so is critical. As long as the front tires are shorter in diameter, you shouldn't have issues. The tire combos I've used on both of my C5's never had any AH/TC issues, even with a much bigger stagger. Fronts are 265/35/18 @ 25.3" tall and rears are 325/30/19 @ 26.7" tall.
For awhile, my former Z06 had 25" tall fronts and 27.2" rears. Those tire sizes were on the car for years, without any issues.
Old Oct 3, 2024 | 04:41 PM
USAZR1's Avatar
USAZR1
I have stock 17x8.5 fronts on all 4 corners: 245/45R17, Stock Rears were: 275/40R18. Front height 25.7", former rear height 26.7".
Any particular reason you're running that tire and wheel combo? Seems kinda strange,IMO.
A cheap solution would be to run 255/45/17's on the rear. That should correct the issue.
Old Oct 3, 2024 | 06:51 PM
wetskier2000
The car has non Bowling Green body panels. I needed to reduce the rear tire size to fit my application. I have changed tire sizes in the ECM/BCM on a different project car. That change corrected the stock C5 speedometer, but I have no idea if TC would see that change since that previous LS1 swapped project car does not have ABS or TC.
Old Oct 3, 2024 | 09:35 PM
USAZR1's Avatar
USAZR1
What are you building, a C5 or something else?
Old Oct 4, 2024 | 08:38 AM
wetskier2000
It's only C5 underneath...
https://www.corvetteforum.com/forums...onet-what.html
Old Oct 8, 2024 | 08:03 AM
wetskier2000
Ok, traction control and ABS seem very confused. I've found a temporary solution was to remove the ABS fuse. Both ABS and TC appear to be permanently off which is fine. Neither is really needed the way this car is driven and no more intermittent TC engagement. I'll revisit after I change the tire size in the ECM/BCM as well as check out the wheel sensors.
Old Dec 30, 2024 | 02:14 PM
Ark1228's Avatar
Ark1228
Have you changed the size in the ECM and had a chance to drive it yet ?
Old Dec 31, 2024 | 08:06 AM
wetskier2000
I have not... Probably won't be til spring as the car is sequestered to the garage for the winter...
Old Dec 31, 2024 | 04:12 PM
grinder11's Avatar
grinder11
If this helps you out....I ran 315-30-18 rear tires with the stock size front tires (245-45-17?) for years and had no issues with TC, AH, or ABS. 315-30-18 rear tires are only 25.44" diameter, and 245-45-17 fronts are 25.68" diameter. Some forum members thru the years have insisted that the rear tires must be of a larger diameter than the fronts are, or you'll run into TC/AH problems. I did not find that to be the case. YMMV.....
Old Dec 31, 2024 | 05:12 PM
lucky131969's Avatar
lucky131969
Ran the same size combo with drag radials on the rears. Never gave me trouble.
Old Jan 5, 2025 | 09:45 PM
streetstrip's Avatar
streetstrip
I ran square 18s "same size front and rear"on an 2003 with no abs or traction control issues or error codes
I ran square 19s "same size front and rear" on a 2000 with on abs or traction control issued or error codes
Never reprogrammed anything on either car
Old Jan 5, 2025 | 09:47 PM
streetstrip
Old Jan 5, 2025 | 11:04 PM
USAZR1's Avatar
USAZR1
A test case of one is not definitive, nor absolute. Just because you got away with doing it, doesn't mean everyone can. The AH/TC system on these cars isn't very sensitive so running a marginally taller front tire may not cause an issue but if it does, that area would be the best place to start.
Old Jan 5, 2025 | 11:06 PM
USAZR1's Avatar
USAZR1
Who offers a 315/30/18 drag radial?
To Tire size and Traction control
