Po300 po106
Old Oct 2, 2024 | 07:35 PM
jooshy's Avatar
jooshy
Cruising
Default Po300 po106
recently did cam and heads on my corvette, got it tuned and it drove absolutely perfect, as I started driving the car harder I bumped into a couple issues. Po300 came up and then later po106, I know these are a random misfire code and a map sensor code.after a couple more days of me trying to figure everything out I started the car and it can barely stay alive without stalling and is not even driveable now. I’m wondering if anybody has ran into this problem, I was thinking vacuum leak but was curious to see what other people think
Old Oct 2, 2024 | 08:08 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Do you have a scan tool where you can look at the MAP sensor voltage or pressure ??
